there is water gallerys that run through the plenum into the side of the block.....
i guess just pull the plenum off and coolant is gonna come out. If u want to put new coolant in just drain it from the bottom radiator hose and that should get most of the coolant out. depends how much u want to refill, but if ur going to need to bleed the cooling system when ur done either way
Ummm no there isn't...
There is coolant lines running through the intake runners but not the plenum. The only coolant that is near the plenum is the two lines that run through the throttle body to stop it from freezing shut.
Edited by PM-R33
