I am currently doing up my project car a 1981 Ford Laser and doing a full respray job on it , doing the car up to be a show car and possibly entering the car in summernats in years to come...
Looking at where to buy Midnight purple paint from ... if anyone has paintcodes for it or if I can get it direct from nissan ?
Anyone got any ideas on where to buy around 4 litres from ?
https://www.sau.com.au/forums/topic/251982-midnight-purple-paint/
You will need the paintcode for it.
BNR32
* KH2 - Gun Grey Metallic
* KG1 - Jet Silver Metallic
* TH1 - Dark Blue Pearl
* AH3 - Read Pearl Metallic
* 732 - Black Pearl Metallic
* 326 - Cristal White
* KL0 - Spark Silver Metallic
* BL0 - Greyish Blue Pearl (special order)
* AN0 - Wine Red
BCNR33
* AN0 - Super Clear Red
* BN6 - Deep Marine Blue
* KH3 - Black
* KN6 - Dark Grey Pearl
* LP2 - Midnight Purple
* QM1 - White
* BT2 - Champion Blue
* KR4 - Sonic Silver (Post 1996)
* AR1 - Super Clear Red II
BNR34
* TV2 - Bayside Blue
* QM1 - White
* KV2 - Athlete Silver
* GV1 - Black Pearl
* AR2 - Active Red
* EV1 - Lightning Yellow
* LV4 - Midnight Purple II
* LX0 - Midnight Purple III
* WV2 - Sparkling Silver
* QX1 - White Pearl
* EY0 - Silica Breath
* JW0 - Millennium Jade
Not 100% sure if these are the same in Australia as I lifted them for a maylasian skyline club page: Source but I thing National Capital motors in Tuggers (I think that who it is) are good with paint code translations.
Only problem now is which midnight purple ><
Edited by Helious
I bought another ltr of lp2 midight purple yesterday from our local piant supplier to finish my engine bay. Just take them in the paint code and tell them how much you need. There should be no drama and takes about 10 minutes. You can only get LP2 in base coat though. So you'll obviously need clear coat to.
Edited by Evocoop
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
