hey guys, when i imorted my 32 gtst it came with 17x9 rays nismo LM GT1 rims. i love them, i would never have thought i would end up with a set, as most people who have commented on them have said how hard they are to come by. im just interested to know a bit more about them. does anyone know if nissan use them on a certian race or production car at any point in time? cheers adam
https://www.sau.com.au/forums/topic/251994-rays-lm-gt-1-rims/
I was going to say, gee they look exactly like my LM-GT2's ... Thanks for the clarification MintR33 !
They are an awesome looking rim. I have them for my circuit racing, love the look... make the car look so much tougher than the VOLK multispoke rims i use for street...
Gary
They are like any other aftermarket wheels, but I believe it is Rays Engineering who make the wheels, do not make them anymore as there are the Nismo LMGT4's now hence why they are rare.
Nissan/Nismo would have used them on their Skylines/Fairladies (Z cars) with their racing events like with the R34 GTR and the 350Z JGTC, they use Nismo LMGT4's.
I would keep them for sure.
Also Revhed01 has a set of White Nismo LMGT2 wheels and looks very nice.
cheers lads. they are a bit scrappy so i want to get them reconditioned. how would i go about replacing the "nismo" decals? also, anyone know a good workshop in brisbane who recondition rims? adam
As good as new, it was cheap, only about $100. Just give yourself a full afternoon to seperate the wheels though it takes alot longer than you'll think.
I planned on getting the middle part machined back to silver and then doing everything in clear but didnt end up doing the machining. Make sure you get the clear though, they recommended it to prevent fading, stone chips etc. Its not much extra either.
  • 4 months later...
Had these for over two years now.
They suit the 32's!
These are 18x10's all round.
Only problem I have had is the inner rim cracking, from fatigue crappy Sydney roads etc.
Got em de buckled, rewelded and machined. Running 265 35R18 tyres all round, as I was running 255 35's, too stretched lol.
Got LM GT1's on my 33 . I tried to get a spare back in 2001 (Scraped a gutter) and was told that it would be almost impossible so I agree, EXTREMELY RARE rims nowdays
You dont have LMGT1's they're LM-GT2's
http://www.skylinesaustralia.com/forums/in...t&p=4607823
Edited by MintR33
They suit the 32's!
That looks tuff as!
Tops it off really well.
That looks tuff as!
Cheers,
Your wheels suit your beast too, gotta get that certain look going!
Only problem is that if these crack again they can't be fixed, so it's gonna be hard to find the 'right' wheels for the beast.
They suit the 32's!
That looks absolutely tuff as!! Love it....do you have anymore pics you can post up??
Thanks Michael. Guess I could.. :D
Now I'm after a replacement center cap! Lost one down at Wakefield park!!grrrr
post-12712-1242985180_thumb.jpgpost-12712-1242985205_thumb.jpg[
attachment=224760:krispy_c...appy_035.jpg]post-12712-1242985237_thumb.jpg[att
  • 4 weeks later...
Bought my car about 3 months ago and they came with the same kinda rims, was just wondering if they are original LMGT 1's or 2's because i cant find any on the net that come in 16"s without the dish. also wondering what they are roughly worth.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
