http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...s=tab%3DSelling
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!please cheak the EBAY link on th top ~!!!!!!!!!
ask for : 250 cash + postage ,
is in 100% good working condition. if you are not willing to pay 250, just bid on it to see can you get it cheaper or not
04 23982768 , or 04 33058572 , just SMS me , DO NOT PM ME , i wont be here for few days
Edited by yuentinlong
  Delta Force said:
that does look very nice ..shame its off an auto :cheers:
no ~ is for MT , you can buy that coz i removed it from my MT car,
the hole that you can see is just because the dash is for AT cluster, but the cluster itself is MT !!!
I'm not sure if that makes sense. So is it the one you're selling in the pic or is it another one? Because the one in your picture you linked is definately from an AT.
= = .... can you understand what i just explain ....
its NOT AUTO CLUSTER !!!!!!!!!!!!!!!!!!!! IT 120% WORKS IN MT CAR, BECAUSE IT IS A MT CLUSTER !!!!!!!!!!
ONLY ONLY the CARBON COVER ON the cluster is originally for AT cluster SO THATS WHY IT GOT A HOLE IN THE MIDDLE
.... :cheers: AGAIN .... IS FOR MT R34 GTT WITH NO DOUBT !!!! IF I WAS WRONG , I WILL PAY YOU 2 TIMES OF THE PRICE included postage !!!!
  Howie said:
Far out chill dude.
If you were clear in your explanation the first time round we'd have understood you.
I am sorry about that , i know i did not explain clear enough ^^:
I reckon if it wasnt for that AT hole you'd have people here fighting over it ..but it's still nice, I just don't think I could handle staring at the hole all the time > One hole staring at another .. not good.
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
