I have a bunch of bits and pieces i need to get rid of asap. All parts located in Sydney and i can email pics on request. All items were in working condition when removed unless i have stated otherwise. Any questions or for pics pm me.
- R32 GTR Series 1 dash modified to have gtst tacho w/clock - Fits all R32's with slight wiring modification (Series 1 should be straight fit for GTR/GTST) $80
- Clutch fans X 2- Suit rb20 possible other rb engines $10ea
- Rb20 crossover pipe w/bov mount $20
- Bottom half of Rb20 plenum $30
- Rb20 (i think) crossover pipe w/o bov mount $20
- Rb20 series 2 timing cover $10
- Rb20 AAC valve $30
- Rb20 PCV valve $20
- Top half Rb20 plenum (has been machined on mounting section so only good for making into custom plenum) $5
- Rb20 exhaust manifold $20
- Top half Rb20 plenum $20
- 10 X Rb20 injectors $15ea
- Rb20 throttle body $20
- Rb20 blow off valve $20
- Rb20 fuel regulator (i think) $20
- New Durapro intake side metal gasket kit w/dump pipe gasket thrown in (not sure which engine its for but not rb20...i think is for rb25/26) $100
- Reco'd VL power steering pump w/rb20 adaptor bracket $50
- Rb20 thermostat housing $5
- VL oil pressure switch $20
- Clutch fork from rb20 box $5
- Rb20 alternator $90
- Rb20 coilpacks - set of 6 w/brackets $100
- Rb20 coilpack loom $50
- Rb20 air con compressor w/belt $50
- Used exedy heavy duty clutch off rb20 - should fit any rb engine (not slipping with 270kw atw) $50
- Rb20 flywheel $50
- Rb20 head (minus intake and exhaust manifolds but otherwise complete) $120
- New VL exhaust manifold gasket (has small cut between No.1 and No.2 exhaust ports but will not affect sealing) $20
- Red neon light roughly 30cm long $20
- Rb20 series 2 valley cover $20
- VL manual ecu (was reco'd in 1999...cant remember if chipped or not) $50
- VL dizzy (no cap or power transistor) $10
- VL afm with airbox top half $30
- VL clutch slave cylinder $10
- VL clutch master cylinder (has not been used for a long time so may need new seals) $40
- VL gearknob $30
- VL commodore/calais owners handbook and product information books in a sundells holden folder (owners handbook good condition/product info book glue is coming adrift at spine) $30
- R32 GTR/GTST passenger side taillight in black $50
- VL fuel pump $30
- VL auto ecus X 3 $30ea
- VL manual pedal box (minus clutch pedal) $10
- Rb20 starter motor $50
- Hornet scoop ( has had fibreglass repair and resprayed white ) $100
- VL afm $20
- VL dizzy complete $50
- VL alternator $50
- VL coils X 2 $10ea
- VL fuel regulator $30
- VL coolant temp sensor $20
- VL tps $20
- VL power transistor $10
And a few other random things...
- Playstation 1 console w/black controller + memory card + cords (no power cord) $10
- Lotus Elan sales brochure circa late 80's (collectors item) $10
- Palsonic 51cm tv w/remote $50
Cheers.
https://www.sau.com.au/forums/topic/251999-r32-stuff-vl-stuff-for-sale-etc/
AC compressor in good condition just a bit dirty. No bearing noise or unusual clutch noise. My AC needed regas so I cant say it was blowing cold recently. Can chuck in the AC belt and brackets etc with it. I can send you pics if you like?
Update:
- 10 X Rb20 injectors $15ea SOLD pending payment
- Rb20 fuel regulator (i think) $20 SOLD pending payment
- Rb20 coilpacks - set of 6 w/brackets $100 SOLD pending payment
- Rb20 flywheel $50
- Rb20 head (minus manifolds and cam caps but otherwise complete) $100
- VL gearknob $30
- VL fuel pump $30
- VL afm $20
- VL alternator $50
- VL tps $20
Update:
- Rb20 coilpack loom $50 SOLD pending payment
- Rb20 flywheel $50
- Rb20 head (minus rocker covers, manifolds and cam caps but otherwise complete) $100
- Rb20 series 2 valley cover $20 SOLD pending payment
- VL gearknob $30
- VL fuel pump $30
- VL afm $20
- VL alternator $50
- VL tps $20
Update + Price Drop...Need this stuff gone:
- R32 GTR Series 1 dash modified to have gtst tacho w/clock - Fits all R32's with slight wiring modification (Series 1 should be straight fit for GTR/GTST) $50
- Clutch fans X 2- Suit rb20 possible other rb engines $5ea
- Rb20 crossover pipe w/bov mount $10
- Bottom half of Rb20 plenum $20
- Rb20 (i think) crossover pipe w/o bov mount $20 SOLD pending payment
- Rb20 series 2 timing cover $5
- Rb20 AAC valve $30 SOLD
- Rb20 PCV valve $10
- Rb20 exhaust manifold $10
- Rb20 throttle body $20 SOLD pending payment
- New Durapro intake side metal gasket kit w/dump pipe gasket thrown in for RB25 Neo engine $100
- Rb20 flywheel $50
- New VL exhaust manifold gasket (has small cut between No.1 and No.2 exhaust ports but will not affect sealing) $20 SOLD pending payment
- VL gearknob $30
- VL fuel pump $30
- VL afm $20
- VL alternator $50
- VL tps $20
- Playstation 1 console w/black controller + memory card + cords (no power cord) $10 SOLD pending payment
- Lotus Elan sales brochure circa late 80's (collectors item) $10 SOLD pending payment
- Palsonic 51cm tv w/remote $50 SOLD pending payment
Update:
- Reco'd VL power steering pump w/rb20 adaptor bracket $50 SOLD pending payment
- Rb20 flywheel $50
- VL gearknob $30
- VL fuel pump $30
- VL afm $20
- VL alternator $50
- VL tps $20
Edited by nIsMo86
Update:
- Rb20 thermostat housing $5 SOLD
- Rb20 flywheel $50
- Rb20 head (minus rocker covers, manifolds and cam caps but otherwise complete) $100 SOLD pending payment
- VL dizzy (no cap or power transistor) $10 SOLD pending payment
- VL gearknob $30
- VL fuel pump $30
- VL afm $20
- VL alternator $50
- VL tps $20
    • We will review wtf is going on, but if you made any donations let me know and i will follow it up with the admins
    • See, that button sounds like perfection Duncan! My eyes really don't like light shining at them from a dash when I'm driving. Being part red colourblind, I've found for most cars that I can change colours on, I set everything to red, so my eyes see the elast amount of colour! I miss normal gauges in cars
    • bro, knowing the Japanese in  the 90's, i wouldn't be surprised if they shared components across their model lineup.
    • Maaaan so many "little" things  i rly hope my old RB20 would be "ok" and not too bad. I try to learn what and what not do i need. I look at crossmember at it looks different...even parts numbers are different. Wiring and all that i rly do not know...yeah someone mentioned the speedo thing. On that yoke clip. I rly do not know what can and cant be done "custom" so that is why iam asking to know and not be suprised 🙂  I know what it looks like
    • Oh, there's also the gearbox crossmember which will probably be different between the small box and the big box, and the wiring loom will probably need to be modified, because the plugs for the switches etc, will probably be different. And I think the speedo on the small box R34s is from somwhere stupid, like the diff, possibly, so you'd need to work out what needs to be done about that (assuming it is different). I think the thing you need to realise is that the front end of that yoke is a large hollow tube with splines on the inside that mates with the splines on the box's output shaft. It is a dedicated thing - not available "aftermarket". They were made to suit that box, by the car's OEM.
