I have a bunch of bits and pieces i need to get rid of asap. All parts located in Sydney and i can email pics on request. All items were in working condition when removed unless i have stated otherwise. Any questions or for pics pm me.
- R32 GTR Series 1 dash modified to have gtst tacho w/clock - Fits all R32's with slight wiring modification (Series 1 should be straight fit for GTR/GTST) $80
- Clutch fans X 2- Suit rb20 possible other rb engines $10ea
- Rb20 crossover pipe w/bov mount $20
- Bottom half of Rb20 plenum $30
- Rb20 (i think) crossover pipe w/o bov mount $20
- Rb20 series 2 timing cover $10
- Rb20 AAC valve $30
- Rb20 PCV valve $20
- Top half Rb20 plenum (has been machined on mounting section so only good for making into custom plenum) $5
- Rb20 exhaust manifold $20
- Top half Rb20 plenum $20
- 10 X Rb20 injectors $15ea
- Rb20 throttle body $20
- Rb20 blow off valve $20
- Rb20 fuel regulator (i think) $20
- New Durapro intake side metal gasket kit w/dump pipe gasket thrown in (not sure which engine its for but not rb20...i think is for rb25/26) $100
- Reco'd VL power steering pump w/rb20 adaptor bracket $50
- Rb20 thermostat housing $5
- VL oil pressure switch $20
- Clutch fork from rb20 box $5
- Rb20 alternator $90
- Rb20 coilpacks - set of 6 w/brackets $100
- Rb20 coilpack loom $50
- Rb20 air con compressor w/belt $50
- Used exedy heavy duty clutch off rb20 - should fit any rb engine (not slipping with 270kw atw) $50
- Rb20 flywheel $50
- Rb20 head (minus intake and exhaust manifolds but otherwise complete) $120
- New VL exhaust manifold gasket (has small cut between No.1 and No.2 exhaust ports but will not affect sealing) $20
- Red neon light roughly 30cm long $20
- Rb20 series 2 valley cover $20
- VL manual ecu (was reco'd in 1999...cant remember if chipped or not) $50
- VL dizzy (no cap or power transistor) $10
- VL afm with airbox top half $30
- VL clutch slave cylinder $10
- VL clutch master cylinder (has not been used for a long time so may need new seals) $40
- VL gearknob $30
- VL commodore/calais owners handbook and product information books in a sundells holden folder (owners handbook good condition/product info book glue is coming adrift at spine) $30
- R32 GTR/GTST passenger side taillight in black $50
- VL fuel pump $30
- VL auto ecus X 3 $30ea
- VL manual pedal box (minus clutch pedal) $10
- Rb20 starter motor $50
- Hornet scoop ( has had fibreglass repair and resprayed white ) $100
- VL afm $20
- VL dizzy complete $50
- VL alternator $50
- VL coils X 2 $10ea
- VL fuel regulator $30
- VL coolant temp sensor $20
- VL tps $20
- VL power transistor $10
And a few other random things...
- Playstation 1 console w/black controller + memory card + cords (no power cord) $10
- Lotus Elan sales brochure circa late 80's (collectors item) $10
- Palsonic 51cm tv w/remote $50
Cheers.
https://www.sau.com.au/forums/topic/251999-r32-stuff-vl-stuff-for-sale-etc/
AC compressor in good condition just a bit dirty. No bearing noise or unusual clutch noise. My AC needed regas so I cant say it was blowing cold recently. Can chuck in the AC belt and brackets etc with it. I can send you pics if you like?
Update:
- 10 X Rb20 injectors $15ea SOLD pending payment
- Rb20 fuel regulator (i think) $20 SOLD pending payment
- Rb20 coilpacks - set of 6 w/brackets $100 SOLD pending payment
- Rb20 flywheel $50
- Rb20 head (minus manifolds and cam caps but otherwise complete) $100
- VL gearknob $30
- VL fuel pump $30
- VL afm $20
- VL alternator $50
- VL tps $20
Update:
- Rb20 coilpack loom $50 SOLD pending payment
- Rb20 flywheel $50
- Rb20 head (minus rocker covers, manifolds and cam caps but otherwise complete) $100
- Rb20 series 2 valley cover $20 SOLD pending payment
- VL gearknob $30
- VL fuel pump $30
- VL afm $20
- VL alternator $50
- VL tps $20
Update + Price Drop...Need this stuff gone:
- R32 GTR Series 1 dash modified to have gtst tacho w/clock - Fits all R32's with slight wiring modification (Series 1 should be straight fit for GTR/GTST) $50
- Clutch fans X 2- Suit rb20 possible other rb engines $5ea
- Rb20 crossover pipe w/bov mount $10
- Bottom half of Rb20 plenum $20
- Rb20 (i think) crossover pipe w/o bov mount $20 SOLD pending payment
- Rb20 series 2 timing cover $5
- Rb20 AAC valve $30 SOLD
- Rb20 PCV valve $10
- Rb20 exhaust manifold $10
- Rb20 throttle body $20 SOLD pending payment
- New Durapro intake side metal gasket kit w/dump pipe gasket thrown in for RB25 Neo engine $100
- Rb20 flywheel $50
- New VL exhaust manifold gasket (has small cut between No.1 and No.2 exhaust ports but will not affect sealing) $20 SOLD pending payment
- VL gearknob $30
- VL fuel pump $30
- VL afm $20
- VL alternator $50
- VL tps $20
- Playstation 1 console w/black controller + memory card + cords (no power cord) $10 SOLD pending payment
- Lotus Elan sales brochure circa late 80's (collectors item) $10 SOLD pending payment
- Palsonic 51cm tv w/remote $50 SOLD pending payment
Update:
- Reco'd VL power steering pump w/rb20 adaptor bracket $50 SOLD pending payment
- Rb20 flywheel $50
- VL gearknob $30
- VL fuel pump $30
- VL afm $20
- VL alternator $50
- VL tps $20
Edited by nIsMo86
Update:
- Rb20 thermostat housing $5 SOLD
- Rb20 flywheel $50
- Rb20 head (minus rocker covers, manifolds and cam caps but otherwise complete) $100 SOLD pending payment
- VL dizzy (no cap or power transistor) $10 SOLD pending payment
- VL gearknob $30
- VL fuel pump $30
- VL afm $20
- VL alternator $50
- VL tps $20
    • Hey all, not sure how active SAU is anymore but will ask away anyways. Just wanted to get some experience on the 2008 model GTR CBA model.  I've hit that age in my life (43) where I'm like fk it time to get my dream (midlife crisis) car. Looking at importing one in and seeing if these can be reliable if the main flaws are fixed up. Plan is to keep money aside to do the following straight off the bat to future proof it: * install a stage 1 rebuilt trans with all new bits and pieces.  * install a new Bellhousing from the later model GTRs. Or potentially an upgraded stronger version like MAD or ATR. Besides the above two things and typical maintenance items anything else you'd recommend doing.   Been speaking to a few people and the engine on these are very reliable apparently. But keen on the view of the community here. Hoping to find a nice grade 4.5 with low mileage in Grey. I'd go black but swirls too easy. Look forward to your responses and feedback. Cheers
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
