R32 Stuff + Vl Stuff For Sale Etc
I have a bunch of bits and pieces i need to get rid of asap. All parts located in Sydney and i can email pics on request. All items were in working condition when removed unless i have stated otherwise. Any questions or for pics pm me.
- R32 GTR Series 1 dash modified to have gtst tacho w/clock - Fits all R32's with slight wiring modification (Series 1 should be straight fit for GTR/GTST) $80
- Clutch fans X 2- Suit rb20 possible other rb engines $10ea
- Rb20 crossover pipe w/bov mount $20
- Bottom half of Rb20 plenum $30
- Rb20 (i think) crossover pipe w/o bov mount $20
- Rb20 series 2 timing cover $10
- Rb20 AAC valve $30
- Rb20 PCV valve $20
- Top half Rb20 plenum (has been machined on mounting section so only good for making into custom plenum) $5
- Rb20 exhaust manifold $20
- Top half Rb20 plenum $20
- 10 X Rb20 injectors $15ea
- Rb20 throttle body $20
- Rb20 blow off valve $20
- Rb20 fuel regulator (i think) $20
- New Durapro intake side metal gasket kit w/dump pipe gasket thrown in (not sure which engine its for but not rb20...i think is for rb25/26) $100
- Reco'd VL power steering pump w/rb20 adaptor bracket $50
- Rb20 thermostat housing $5
- VL oil pressure switch $20
- Clutch fork from rb20 box $5
- Rb20 alternator $90
- Rb20 coilpacks - set of 6 w/brackets $100
- Rb20 coilpack loom $50
- Rb20 air con compressor w/belt $50
- Used exedy heavy duty clutch off rb20 - should fit any rb engine (not slipping with 270kw atw) $50
- Rb20 flywheel $50
- Rb20 head (minus intake and exhaust manifolds but otherwise complete) $120
- New VL exhaust manifold gasket (has small cut between No.1 and No.2 exhaust ports but will not affect sealing) $20
- Red neon light roughly 30cm long $20
- Rb20 series 2 valley cover $20
- VL manual ecu (was reco'd in 1999...cant remember if chipped or not) $50
- VL dizzy (no cap or power transistor) $10
- VL afm with airbox top half $30
- VL clutch slave cylinder $10
- VL clutch master cylinder (has not been used for a long time so may need new seals) $40
- VL gearknob $30
- VL commodore/calais owners handbook and product information books in a sundells holden folder (owners handbook good condition/product info book glue is coming adrift at spine) $30
- R32 GTR/GTST passenger side taillight in black $50
- VL fuel pump $30
- VL auto ecus X 3 $30ea
- VL manual pedal box (minus clutch pedal) $10
- Rb20 starter motor $50
- Hornet scoop ( has had fibreglass repair and resprayed white ) $100
- VL afm $20
- VL dizzy complete $50
- VL alternator $50
- VL coils X 2 $10ea
- VL fuel regulator $30
- VL coolant temp sensor $20
- VL tps $20
- VL power transistor $10
And a few other random things...
- Playstation 1 console w/black controller + memory card + cords (no power cord) $10
- Lotus Elan sales brochure circa late 80's (collectors item) $10
- Palsonic 51cm tv w/remote $50
Cheers.
Update:
- 10 X Rb20 injectors $15ea SOLD pending payment
- Rb20 fuel regulator (i think) $20 SOLD pending payment
- Rb20 coilpacks - set of 6 w/brackets $100 SOLD pending payment
- Rb20 flywheel $50
- Rb20 head (minus manifolds and cam caps but otherwise complete) $100
- VL gearknob $30
- VL fuel pump $30
- VL afm $20
- VL alternator $50
- VL tps $20
Update:
- Rb20 coilpack loom $50 SOLD pending payment
- Rb20 flywheel $50
- Rb20 head (minus rocker covers, manifolds and cam caps but otherwise complete) $100
- Rb20 series 2 valley cover $20 SOLD pending payment
- VL gearknob $30
- VL fuel pump $30
- VL afm $20
- VL alternator $50
- VL tps $20
Update + Price Drop...Need this stuff gone:
- R32 GTR Series 1 dash modified to have gtst tacho w/clock - Fits all R32's with slight wiring modification (Series 1 should be straight fit for GTR/GTST) $50
- Clutch fans X 2- Suit rb20 possible other rb engines $5ea
- Rb20 crossover pipe w/bov mount $10
- Bottom half of Rb20 plenum $20
- Rb20 (i think) crossover pipe w/o bov mount $20 SOLD pending payment
- Rb20 series 2 timing cover $5
- Rb20 AAC valve $30 SOLD
- Rb20 PCV valve $10
- Rb20 exhaust manifold $10
- Rb20 throttle body $20 SOLD pending payment
- New Durapro intake side metal gasket kit w/dump pipe gasket thrown in for RB25 Neo engine $100
- Rb20 flywheel $50
- New VL exhaust manifold gasket (has small cut between No.1 and No.2 exhaust ports but will not affect sealing) $20 SOLD pending payment
- VL gearknob $30
- VL fuel pump $30
- VL afm $20
- VL alternator $50
- VL tps $20
- Playstation 1 console w/black controller + memory card + cords (no power cord) $10 SOLD pending payment
- Lotus Elan sales brochure circa late 80's (collectors item) $10 SOLD pending payment
- Palsonic 51cm tv w/remote $50 SOLD pending payment
Update:
- Reco'd VL power steering pump w/rb20 adaptor bracket $50 SOLD pending payment
- Rb20 flywheel $50
- VL gearknob $30
- VL fuel pump $30
- VL afm $20
- VL alternator $50
- VL tps $20
Edited by nIsMo86
Update:
- Rb20 thermostat housing $5 SOLD
- Rb20 flywheel $50
- Rb20 head (minus rocker covers, manifolds and cam caps but otherwise complete) $100 SOLD pending payment
- VL dizzy (no cap or power transistor) $10 SOLD pending payment
- VL gearknob $30
- VL fuel pump $30
- VL afm $20
- VL alternator $50
- VL tps $20
 Share
