Update:
- R32 GTR Series 1 dash modified to have gtst tacho w/clock - Fits all R32's with slight wiring modification (Series 1 should be straight fit for GTR/GTST) Also good for parts $50
- Rb20 crossover pipe w/bov mount $10
- Bottom half of Rb20 plenum $20
- Rb20 (i think) crossover pipe w/o bov mount $20 SOLD
- Rb20 series 2 timing cover $5
- Rb20 PCV valve $10
- Top half Rb20 plenum (has been machined on mounting section so only good for making into custom plenum) $5
- Rb20 exhaust manifold $10
- Top half Rb20 plenum $20 SOLD
- 10 X Rb20 injectors $15ea SOLD pending payment
- Rb20 throttle body $20 SOLD
- Rb20 blow off valve $20 SOLD pending payment
- Rb20 fuel regulator (i think) $20 SOLD pending payment
- New Durapro intake side metal gasket kit w/dump pipe gasket thrown in for RB25 Neo engine $100
- Reco'd VL power steering pump w/rb20 adaptor bracket $50 SOLD
- Rb20 thermostat housing $5 SOLD
- VL oil pressure switch $20
- Clutch fork from rb20 box $5
- Rb20 alternator $90
- Rb20 coilpacks - set of 6 w/brackets $100 SOLD
- Rb20 coilpack loom $50
- Rb20 air con compressor w/belt $50
- Used exedy heavy duty clutch off rb20 - should fit any rb engine (not slipping with 270kw atw) $50
- Rb20 flywheel $50
- Rb20 head (minus rocker covers, manifolds and cam caps but otherwise complete) $100 SOLD pending payment
- New VL exhaust manifold gasket (has small cut between No.1 and No.2 exhaust ports but will not affect sealing) $20
- Red neon light roughly 30cm long $20
- Rb20 series 2 valley cover $20 SOLD
- VL manual ecu (was reco'd in 1999...cant remember if chipped or not) $50
- VL dizzy (no cap or power transistor) $10 SOLD pending payment
- VL afm with airbox top half $30
- VL clutch slave cylinder $10
- VL clutch master cylinder (has not been used for a long time so may need new seals) $40
- VL gearknob $30
- VL commodore/calais owners handbook and product information books in a sundells holden folder (owners handbook good condition/product info book glue is coming adrift at spine) $30
- R32 GTR/GTST passenger side taillight in black $50
- VL fuel pump $30
- VL auto ecus X 3 $30ea
- VL manual pedal box (minus clutch pedal) $10
- Rb20 starter motor $50
- Hornet scoop ( has had fibreglass repair and resprayed white ) $100
- VL afm $20
- VL dizzy complete $50
- VL alternator $50
- VL coils X 2 $10ea
- VL fuel regulator $30
- VL coolant temp sensor $20
- VL tps $20
- VL power transistor $10
And a few other random things...
- Playstation 1 console w/black controller + memory card + cords (no power cord) $10 SOLD
- Lotus Elan sales brochure circa late 80's (collectors item) $10 SOLD pending payment
- Palsonic 51cm tv w/remote $50 SOLD pending payment
Another Update:
- Used exedy heavy duty clutch off rb20 - should fit any rb engine (not slipping with 270kw atw) $50 SOLD pending payment
- Rb20 flywheel $50
- VL Turbo manual ecu (was reco'd in 1999...cant remember if chipped or not) $100
- VL gearknob $30
- VL fuel pump $30
- VL manual pedal box (minus clutch pedal) $10 SOLD pending payment
- VL afm $20
- VL alternator $50
- VL tps $20
Update + Added stuff:
- 92 GTST Drivers Side Indicator Orange (Locating knob snapped off) $20
- Fibreglass GTR copy front bar - Removed from 92 GTST (Has crack and minor damage...also bottom lip chopped off) $150
- Sr20 fuel regulator $20
- Rb20 coilpack loom $50 SOLD
- Rb20 flywheel $50
- VL gearknob $30
- VL fuel pump $30
- VL afm $20
- VL alternator $50
- VL tps $20
  • 1 year later...
  • 2 months later...
  • 4 weeks later...
is the clutch slave off a mx7 or mf5, would u know if there the same as a rb20 slave? or maybe get some picks?
thanks
The slave is a pbr item off an mf5 but was being used with an rb20det gearbox. I'm not sure if they are the same but they look identical in size and worked fine with rb20 box in vl. I will try to get you a pic shortly.
hey mate would you have a rb30et standard exhaust mani???
No sorry no vl turbo manifold.
Cheers.
thats cool if your saying it worked fine in a rb20 most likely will be fine, just to get me going again anyway. Does it come with cylinder and push rod? and will you post to melb?
  • 7 months later...
  • 2 months later...
    • Thanks again, really helpful chap from alpha omega wanted to speak to me, little concerned if this is meant to he aero alloy/ airospace quality and car sitting on drive has caused this.  Airplane are subject to much more changing temp and conditions than road salts! My caliper, many other components much older have surface rust but never eating part of the metal   Had I not seen it , could have been a disaster! specifically on rear part of bracket coming off like biscuit will update on what they say, helpful people so far
    • January or Feb is it booked in for turbo fitment?
    • The MX5 has had some annoying rattles in both front doors over bumps So I installed fancy pants door bushings, which stopped all of the rattles with the windows up, but........with the windows down there was still rattles, so after some googling,  and a chat with MX5 Mania, I got some new door to glass weather seals, all the rattles, windows up, or down, are gone now Shout out to MX5 Mania, the weather seals were on sale, and when I head to Dural to pick the up they even fitted them for me for free I did see a "really" nice Blue NA sitting out front   and this Black NC PRHT that looked like it has sat in the sun for its whole life and never had a wash, the clear coat was non-existent, an it looked horrible, really horrible, but, it had a nice turbo kit with over 200kw, the thing went like a cut snake, bagging the rears through the gears and dosing like a champ 😍 But, as I've always stated, I am keeping my NC na, I'm happy with the current power the car makes In other news: MX5 Mania do a drive in drive out turbo kit, the only minor additional part recommended for boosting my car, as it sits now, is a oil cooler, and that bonnet vents are definitely required for track use Aftermarket version look a bit to "racecar" spec I wonder how Focus RS bonnet vents would look?????
    • Paint is only structural when applied to the outside of Chinese and Indian cars. Otherwise it should never be present between mechanical joints that were intended to be metal to metal. Pain slips, slides, cracks, compresses, and add thickness that wasn't intended to be there. It comes firmly under the category of "just no".
    • appreciated it thanks   There are threads on the adaptor. I rear re anodising but didn’t know it will reduce strength   re mating services needing to be flat/ not painted, why would that be? I am devastated as car been off for a year, fixed power steering then installed bm57 master cylinder and just before driving it this came up. So annoyed   worried and afraid to drive it, no fun caliper coming off
