Not a Skyline I know fella's but someone may want to come across to the dark side.
Item: 91 Cressida Glx 1JZ Twin Turbo
Item Condition:Good
Price and Payment Conditions: 8500 ono No Swaps thanks.
Contact Details: PM or 0407332944
Considering selling my car as I've found another one I would like to buy and the wife wants a car with airbags, abs etc for our baby on the way. The car has 14XXXX kms and is a 2 owner car before I bought it. I've upgraded evrything on this car including:
- Amistad 3 piece 18*8 & 9wheels with yokohama 235/40 and 255/50 tyres
- KYB suspension brand new Rav4 front shocks and Supra rear with kings springs, upgraded rear sway bar
- R33 brake calipers on BA Faclcon Discs with Project Mu pads on the front a new rear pads
- 1JZ twin turbo engine from JZX81 Front cut
- Titan adjustable cam gear on exhaust cam
- custom dump pipe into 3"system with genuine Metalcat
- Walbro fuel pump
- SAFC and SITC combo
- 600x300x75 tube & fin intercooler
- Grande LSD
- Momo woodgrain steering wheel
- Pioneer head unit with clarion splits in the front 6"kenwoods in the rear and 2x10"clarion woofers in a box in the boot powered by a kenwood amp
More info available in my members ride thread:
http://www.toymods.net/forums/showthread.p...highlight=bogan
Here are a few pics:
The car drives beautifully and I only drive it on weekends as I walk to work.
The only things that detract from the car are the minor trolley dents in it and some scratches which you can see up close so it's not in concourse condition but its pretty good for a 17 y.o. car!
Just fitted some new turbo's on the car last weekend.
The wiring was done professionally by Mos so you know thats done right and this car is registered with the 1JZ in it but other states may need engineering but I think once it's registered here it may not so it would be best to check.
I am chasing $8,500 for it which is pretty sharp for a car with this amount of time and money spent on it.
Cheers
Rich
0407332944
https://www.sau.com.au/forums/topic/252005-twin-turbo-cressida/
  • 1 month later...
Ok need to sell this now as I've just bought a JZX90. I'm willing to strip some parts off the car to reduce the price such as the wheels which I will put on the 90 and a few other bits and pieces. I will put some 17's or maybe some GTST 16's on the car and will consider somewhere btw $6 and $7K depending on what you want brakes , cam gear, stereo, SAFC/SITC combo etc. Basically you can have a series 2 1JZ cressida with a genuine 144K on the clock for less than it costs to buy and do one yourself. Hit me up with offers!!!!!
Cheers
Rich
0407332944
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
    • How complicated is PID boost control? To me it really doesn't seem that difficult. I'm not disputing the core assertion (specialization can be better than general purpose solutions), I'm just saying we're 30+ years removed from the days when transistor budgets were in the thousands and we had to hem and haw about whether there's enough ECC DRAM or enough clock cycles or the interrupt handler can respond fast enough to handle another task. I really struggle to see how a Greddy Profec or an HKS EVC7 or whatever else is somehow a far superior solution to what you get in a Haltech Nexus/Elite ECU. I don't see OEMs spending time on dedicated boost control modules in any car I've ever touched. Is there value to separating out a motor controller or engine controller vs an infotainment module? Of course, those are two completely different tasks with highly divergent requirements. The reason why I cite data sheets, service manuals, etc is because as you have clearly suggested I don't know what I'm doing, can't learn how to do anything correctly, and have never actually done anything myself. So when I do offer advice to people I like to use sources that are not just based off of taking my word for it and can be independently verified by others so it's not just my misinterpretation of a primary source.
    • That's awesome, well done! Love all these older Datsun / Nissans so rare now
