I was looking at my cat the other day, and i noticed that there is a sensor in the cat,i think its a secondary 02sensor.Anyway its been weld to the cat so if it is a 02 then im guess that it would be stuffed after the heat of being welded.Where can i get new 1 and whats it there 4.
https://www.sau.com.au/forums/topic/25201-wtf-is-the-sensor-in-the-r33-cat/
The EGT sensor illuminates a warning light which looks like a side view of the catalytic converter with wavey heat lines coming off the top of it (looks more like a BBQ!) It will illuminate when the temperature has reached around 850 degree celcius. This is very hot, and is usually due to either driving the car very hard continuously (ie: around a race track) or if driving normally is due to an extremely lean engine conditions (not good! perhaps a lazy fuel pump?)
This doesn't affect the operations of the ECU, but serves its purpose to help protect both the turbo from excessive heat (ceramic turbines in particular) from high temp failure and also to help the Platinum Rhodium material in the catalytic converter from being heat damaged.
Heat damage reduces the cat's ability to convert carbon monoxide and other poisonous gases back to a safe (and legal) emissions standards. Most cats don't work too well after 80,000km's anyway, from what i've been told.
If you ignore the warning light, then i think you'd be taking a blind eye to a possible engine problem if the light come on when you were just driving around normally (ie: not doing laps on a track)
Hmm, could be a faulty EGT sensor, but i still think that it could be indicating an engine that is running a bit too lean. I hear stories from a dyno operator i know here that sees cars that come in every day that have been so called "tuned" or "dynoed" that run extremely lean in the quest to extract as much power as possible. He says that some performance shops tune the cars so aggressively to extract as much power as possible to impress their customers, when in reality it's better to tune conservatively on a street car taking into consideration different qualities of fuel from batch to batch, different ambient temps, etc, etc. Too many variables to consider, and you should be factoring in some reliability into the engine with some form of thermal control. (A bit richer from Stoichiometric)
Anyway, i'm rambling again, get it looked into! At least check your fuel pressure and A/F ratios, as a EGT warning is a rare instance on a street car, i'm told.
um mods where safc,fmic,9psi,hks filter hi flow muffler. 212hp or round there.They told me my exhaust is causing issue's.I think the fuel pump is stuffed to.Seeings im not driving it im saving heaps of cash and im getting 3inch turbo back exhaust,255lpr pump,malapasi reg,To4e,plenum modified like a gtr style.Cause i think the turbo is a bit tired.Ill see how that runs if it still unpowerd then wolf3d,injectors,manual.I do alot of my mods myself (still building 327hp sohc vtec civic,time for body work:)
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
