are you sure it was an RB? i remember a VQ30DET with a manual gearbox doing some burnouts in a street
Thats the white one, yeah?
Im thinking of a red one (or Pink as we'd refer to it when Stephen owned one). Im not having too much luck on the googles, perhaps I'm going insane pinch.gif
  • 6 months later...
A NZ bloke who seems to pop in occasionally is the closest to getting it done. "dcdc" is his user name.
Last time he checked in he had a R34 getrag 6spd (I think, i know it was a GTR box) in the car, had to be a custom bellhousing. Combination of parts isn't that hard to work out- GTR box, V35 pedal box and clutch cylinder, Flywheel off something to suit, clutch plate.
Then a load of head f**ks getting the ECU to take to something with different speed inputs / loads etc etc, as the ECU was never designed to work with a manual box- so its not a matter of switching auto/manual ECUs.
He had to cut the floor plan too to fit in the T case.
RWD would be no doubt simpler, but you'd still have to get around the electrics side of things- just use a V35 1/2 cut.
Whatever option you choose, expect north of 5 or 6k for the RWD, and double that if going the AWD as my guess. Thats if you expect drive in drive out. If you are a fabricating God, then you'll already know where to start.
Actually dcdc is in Brisvegas. I dropped in to see his M35 a few weeks back. Looks quite the project but still a long way off being completed.
Yes a different KIwi manualised an M35 2wd with a custom bellhousing and Toyota box - used a Link wire in to run the engine (turboed 3L)
Yeah I remember that one, it was in a Mag, and saw a vid of it doing skids. Its was a VQ30det from memory. Different ECU setup from these VQ25det guys. Think it was out of a Gloria or something.
  • 1 year later...
**Thread Revived**
So if I understand correctly from what I've read here the last page's...
"Converted from an automatic RS4 and had a totally reconditioned r32gtr box with a set of nismo heavy set gears whacked into it"
...right!?
...otherwise you have to say that there is nothing what you can do even without spending a fortune equal.
Bad story,for this car :(
The C34 one has been more effortless!
**Thread Revived**
...right!?
The C34 was released in manual, and has a programmable ecu. The M35 does not, and parts seem to be nearly impossible to find. (I have been trying to find a manual V35 console and handbrake for years)
The conversion is still going ahead, as soon as my Evo is built and on the road. I just hope I can find at least the handbrake by then.
Didn't the m35 have the 350s with the factory manual?
Yes.
It was a series one car modified by Autech.
And Scotty is just being a bish. All he needs is a wrecked manual V35 S1 sedan, but he keeps buying nugget Stageas for parts cars...
:P
Yes.
:P
Series 2 you mean?
There is no gearbox other than the RE5 that bolts up to our orphan, I need to swap the sump so the bolts line up on the 350x box, and the starter fits. There is a lot of mechanical work before I even get to the electronic side. :/
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
