Any of those will be a terrific asset to your garage if
i) there's absolutely no prevalent rust
ii) no damage has occurred unless properly repaired
iii) engine is in top nick
iv) there's service history
v) running gear and suspn have minimal wear or replacements are up to spec
vi) low kms that correspond to carpet wear/ bolster wear/steering wheel wear
vii) brakes are good cond (and if possible upgraded in the R32)
viii) little or no track work
ix) the former owner/s is/are as old as I am. hehe
Check that there's no hesitation as you accelerate
Check that there's no vibration at constant speed runs for 10 sec at a time (wrt tail shaft)
Check amount of smoke and what type is coming out of the exhaust as someone follows you on a run.
Do tight circles clockwise and anticlockwise (wrt CVs)
If you're not mechanically minded, take someone who is with you on any inspection. He'll have his check-list whilst you have yours.
Enough for now?
Enough for now?
And a pile of cash to continually look after her. lol
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
    • You would need to paint your hardtop again though
    • I have an old R32 in the shed that hasnt moved much in the last few years and probably should see the light of day. At one point I had a Nismo 1.5 centre put in the rear diff. It is a clunky nightmare POS of a thing on a good day. To make it less painful the initial torque setting has been put on the minimum (7.0kgf-m, mid is 9.5, high is 14) and the oil changed out to something more slippery. But it is still awful and ruins the vibe of the thing. So my questions are: Given I have the original parts sitting in a box somewhere would it be better to rebuild the thing again, reverting to more purity? Is there a standard kit or do you just go and replace the friction plates etc and shim it the way you like it. How much initial torque does the standard R32 rear diff have? Or does the Nismo disc kit offer a better solution - the caveat being the initial torque for both options appears to be higher than the clunky 1.5 way. There appear to be two Nismo disc kits: 3843S-RS520 for 8kgf-m. 3843S-RS521 for 12kgf-m. Or is the easiest solution to reshim the Nismo diff to make it looser?
