Hi guys...
I have a bit of a problem , yesterday while washing my r34 i noticed a log crack on my windscreen , so now i need to find someone who can source a screen for a r34 sedan.
Has anyone has their wind screen replaced on a R34 sedan in sydney , i need someone soon cause the crack is starting to bigger.
Cheers
Pac...
https://www.sau.com.au/forums/topic/252136-r34-windscreen/
Last time I got a crack on my windscreen on my previous car, I just called up my insurance company and they gave me a free windscreen. I think i'm entitled to one per year. Might be worth seeing if your insurance company can do the same. Btw, they sent me to Windscreens O'Brien.
https://www.sau.com.au/forums/topic/252136-r34-windscreen/#findComment-4361636
Thanks for the fast replay guys.
I have called up a guy in sydney that might be able to get the windscreen I'm waiting for him to call me back.
Originally i have sourced a screen from a import place but it was for a coupe.... and they are slightly different from the sedans , so if anyone has a sedan and had the windscreen changed can you tell me if the screen is hard to source?
Cheers
Pac...
https://www.sau.com.au/forums/topic/252136-r34-windscreen/#findComment-4361703
Just an update guys
I have call 3 places yesterday
M&M Windscreens
O'Briens
National Windscreens Group
So far all of them have told me they will need to call me back since they can only source the coupe windscreen and don't have any sedan screens in stock.
https://www.sau.com.au/forums/topic/252136-r34-windscreen/#findComment-4364071
Ok guys
The guys and M&M have been able to get me a screen , but the cost is around 450 installed.
I know that a bit expensive but i can't risk driving for too long on the road with a cracked windscreen.
I have had no replay from O'Briens and National Windscreens Group so far and the guys at Novus windscreens were the worst didn't even bother getting my details just asked for a contact number and said they will call back.
I have made a apointment to have the screen replaced on thursday.
I'll updated you guys after it is all done.
Cheers
Pac...
https://www.sau.com.au/forums/topic/252136-r34-windscreen/#findComment-4364534
Well its either $450 or risk the troubles in the long run for a cracked windscreen.
$450 sounds ok, prices may have gone up since I got mine done in 2005 and its a R32 as yours is a R34...
Have you tried to give Nissan a call? See what they say, but Im sure to say $450 is a better price then what Nissan will quote.
https://www.sau.com.au/forums/topic/252136-r34-windscreen/#findComment-4364626
Just an update guys.. i have got the screen replaced by M&M windscreens , on tyhe same day i got a call back form O'Briens quoting me around $600 to install.
But i told them they were too late already got someone else to install it for less.
Thanks for the help guys.
https://www.sau.com.au/forums/topic/252136-r34-windscreen/#findComment-4392559
    • I would like more noise related info for my truly uneducated guess  Does it do it at idle or when revving, clutch engaged, and disengaged? Does it only do it when the car is moving? I've heard "similar" noises from a clutch pack that left the chat room, and CV joints that have chewed themselves out But as Matt said, how's the yokes, tailshaft and centre bearing going after their last little issue Fingers crossed it is something simple  Weird noises make me cringe
    • One other question, is there a chance that changing the idle speed can lead you down a rabbit hole and is the reason the tuner didn't touch it? Reason I ask is because if that's the reason the tuner avoided it then I probably shouldn't be touching it lol.
    • Pfft. As if I'd ever point a high pressure washer at my car.
    • The nature of my commute has changed. Way back then it was traffic lights all the way, for ~28km. It sucked. When they finally stitched the expressway together I could do a good 15+km of it at a steady 80-100 with no stopping. That alone has gotten me down to flat 10s. Prior to that it was mid-high 10s. I can't remember the delta that I saw when I got the idle down. It was only ~150 rpm, because the idle speed was never terrible, but for the delta in consumption to be noticeable it would have had to have been at least 0.2-0.3 L/100km - which is not to be sneezed at when it comes for absolute free. It's only about 50L per year, but that's ~$100. A few extra pizzas is always welcome. Note that I have a record of every tank of fuel that has ever gone through my car except for a handful put in by someone else, like my mechanic. I can show you the difference between stock RB20 and tuned RB20, stock RB5Neo and tuned, winter and summer fuel blends, winter and summer fuel blends when the ambient temperature is not appropriate for the blend, working O2 sensor, blown O2 sensor, boosting f**k out of it and frightened to boost it because it is pinging, and so on. OK, I probably can't do all that now with 100% clarity - but at the time when any of those things were in event, you could see it in the records. There's 25+ years of simple tank after tank records, so you have to look for landmarks to work out approximately how old any single record is. What's really important is the meta data and that lives in my head.
    • If you're claiming the issues are not skyline specific, then either the USA is living in the 90s / early 2000s, OR you have the issue of "survivor bias". Which is you're mainly hearing and listening to those with terrible experiences, and haven't found the guys who have cars with good decent builds and no problems. It happens in AU too, that plenty of people keep having issues, and they keep going to the workshops that are known to be shit "because I read on the internet". Even worse, are those who keep posting on the internet as though they know for a fact what something is, when they've never touched/looked at said item in their life, and again are making assumptions, based on something they read, or because it's a certain way in other cars. It's even funnier when those same people debate the facts with the people who've lived and breathed this stuff for over 15 years. Example, I've had someone tell me you can't do something with a Skyline, because they read it on the internet, except I can tell they're wrong, as I did that exact thing back in 2008 with my Skyline.
