1995 Nissan Skyline R33 Grey GTR V-SPEC
Due to a change of circumstance (my other project being defected & EPA'ed), I now must sell this recently acquired vehicle.
Vehicle has just undergone a full service, everything has been inspected and is ready to go.
230 kw @ the wheels runnig 13 psi before installation of the cam gears & exhaust (as per previous owner).
I am interested in a car worth approx 6-7k as part of the deal, which must be standard (no more - please do not ask).
Considerable time and money have been spent bringing this vehicle up to a standard that I am happy with on selling.
As per previous owner, 4th gear syncro worn & 4th gear does occasionally crunch (common with these gearboxes), apart from this issue, car drives and behaves as it should.
The asking price is very fair & I am looking for a quick sale to pay substantial fines due late this month.
Price will be $19,000 with RWC and reg for Vic buyers or $18,000 without (as is, where is).
No time wasters, if your interested, details below.
DO NOT POST IN HERE - ANY QUESTIONS OR COMMENTS, PM ME.
- Apexi Power FC
- Greddy Turbo Timer
- Spool Adjustable Cam gears
- Alarm With Remote
- Alloy Intake Piping
- Greddy Pod Filters
- Splitfire Coil Packs
- XS Power Stainless Front Pipes
- Stainless Steel 3" Cat Back Exhaust
- N1 Water Pump
- Xtreme HD Clutch
- Lightened Flywheel
- Alarm With Remote
- Slotted Front Rotors
- Brembo Brakes Front & Rear
- Lenso D1R 18" Wheels On Near New Tyres
- ZEAL 10/8 Coilovers, Height, Damper & Springrate Adjustable
- New Superpro Adjustable Caster Rod Bushes
- New Superpro Adjustable Camber Bushes
- New Leather Gear Boot
- New Leather Hand Brake Boot
- Alloy Shift Knob
- OMP Deep Corn Racing Wheel With Boss Kit (must be removed for RWC).
- Sony Xplode MP3/CD Head Unit
- Focal Front Splits
- Pioneer Rear Speakers
- Front Doors DYNAMAT Insulated
- Genuine GTR Floor Mats Front & Rear
Phone - 0439 745 842
Email - [email protected]
https://www.sau.com.au/forums/topic/252208-1995-nissan-skyline-gtr-v-spec-grey/
hi mate - just a quick question...as you are the owner of this car, didn't you need a RWC to transfer it into your name anyway? In which case, the RWC you used should still be valid and the new owner won't need to get one. Just a thought as it may save yourself or the next owner some $$$
Correct me if I'm wrong but if its the same as in QLD, you can only use the rwc once. You have to give the department of transport a copy when you transfer it into your name.
no, RWC is valid by dates, not by the number of times it is used. in fact, this is the same in Qld as well - I just sold a V35 on the same RWC (safety certificate) as I used to rego it (which the next person also used to rego it). as long as it was within 30 days (or 500klms or something like that)
Agreed. I Just did this less than 3 weeks ago...
  • 1 month later...
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
    • I did say no low balling (Insert copy and paste article from Motor mag with complete history of R32 GTR development and racing history here)
