  • Replies 82
lol..yea sometimes i do..guess thats why..atm im running 2 amps.. 1 - 800wattx4 and a 225wattx2 on my splits + tweeters and 2 12`subs.. havent got anything hooked up to the 4 ways in the back.. and yeah ive got all the blu neon crap in the car and boot so yeah does drain a bit of power..
https://www.sau.com.au/forums/topic/25225-boot-install-pics/#findComment-537655
Originally posted by sHorty
BTW does that box u made work well like the bass sounds good through it
the neons sux shit loads of power from the battery!
The sub i got is a 12" Orion MTX close enclosure sub, and the box was custom made at a car audio place. Works really well and shakes the front windscreen but to much of the boot 2!
https://www.sau.com.au/forums/topic/25225-boot-install-pics/#findComment-537972
neons are old school man.. buy CCFL's.. less power drain..
I reckon you can build some pretty awesome stuff if you muck around a bit and have a bit of creativity. Once you have some nice carpet, you can make some templates and go to town. Bit of perspex, some MDF and a jigsaw (or dremel), maybe get some polished metal designs cut to the shape you want, few CCFL's..
Pproblem is the skyline boot is pretty squishy, thats why most comp cars are hondas and crap with big boots. Might stuff around with that in my next car, with the R33, its a bit like meh.. its never going to look awesome.
u can get pretty good results with DIY if you put the time in.. see my box :D it took a few hours, but i saved a fair bit of money and I think it sounds pretty good. You learn a bit I guess, and once you start you kind of think.. hmm, i could do this and this and this next time.
http://www.skylinesaustralia.com/forums/at...=&postid=519631
https://www.sau.com.au/forums/topic/25225-boot-install-pics/#findComment-537988
Has anyone done a full custom box to fit in the side parts of the boot, or maybe the spare wheel bay..
It'd be good to save a lot of room and use either of those two spaces. I not build a sub box before, but I imagine custom making something to fit these spaces would be a fairly tedious job..
https://www.sau.com.au/forums/topic/25225-boot-install-pics/#findComment-538799
Here's mine.
I was going to make a fibreglass box in the rear wing but ultimately decided on the easier route. I need to make some sort of cover where the fuses are. The sub's not in a box so probably doesn't perform at it's best (still sounds good enough for me).
Of course i'm bolloxed if I ever want to fit a strut brace!
https://www.sau.com.au/forums/topic/25225-boot-install-pics/#findComment-538815
That looks heaps nice dude.. but unfortunately i have already used up all that space:
http://hal.ooix.net/images/displayimage.ph...?album=5&pos=30
Amp to go under the a/v box that the cut out shows (mainly for air flow and access purposes - may pretty it up later with tinted viewing window and neon :) I have measured up the area and will fit audison srx3 perfectly.. :)
Will have to put the sub(s) somewhere else obviouslly :P
https://www.sau.com.au/forums/topic/25225-boot-install-pics/#findComment-538826
Originally posted by Moschops
Here's mine.
Ive seen a r33 like that install but with 2 flush mounted amps and sub in same location, looks preety good.
I had a big problem with mine when i had to change a flqt tyre, it involved pulling half of my system out to get to the spare wheel!!
https://www.sau.com.au/forums/topic/25225-boot-install-pics/#findComment-538840
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
