  • Replies 82
Originally posted by halz
Has anyone done a full custom box to fit in the side parts of the boot, or maybe the spare wheel bay..
It'd be good to save a lot of room and use either of those two spaces. I not build a sub box before, but I imagine custom making something to fit these spaces would be a fairly tedious job..
I am currently making a box to fit into the left hand side of the boot (for a 10" sub). I'll let you know if it is a success or dismall failure. Should be finished this week. I'll post a pic or 2 if it works out. Bitch of a job though...
Originally posted by hippy
yep workin on the car is always a bitch of a job especially if u dont' know what ur doing  :rolleyes:
Hehe... If all goes well I might be finished today (after work :) ) It's looking ok so far, it fits nicely and there is plenty of room left in the boot. Best of all I can still get the spare out. I also remade the panel at the back of the boot (the one that hides the battery) with a stronger one to mount the amp, fuse holder and cap (this will be modded again later to mount my stacker).
Yeah i did a similiar thing - remade a back wall out of mdf and have attached the xbox and will attach the amp once i can afford it !
Works very well.. can see it http://hal.ooix.net/images/thumbnails.php?...?album=5&page=2
Good job! I could not match the carpet colour in my boot so I had to use a darker carpet, it still looks ok though. Whoever had my car before me butchered the back wall.
    • Sane enough. Remove the roof liner, because the acid will go everywhere.
    • Thanks guys, I really appreciate the help and experienced opinions.  I have spent a lot of my life working on boats so I'm pretty good with fibreglass. I'll take everybody's advice in here;  I'll cut a little more of the 2nd layer away as it's a bit crunchy rust and also it's sitting high now. Then I'll wire brush it all a bit to get off anything loose, then I'll soak the bejesus out of it all in rust converter. I'll make sure to get a little hose piece and feed it into all the holes and gaps between the roof layers. Then I'll fibreglass up the holes.  Then I'll get a pallet of filler and mix it with 3 buckets of hardener and hope that is enough to build up the roof corner.  Does that sound sane? Is one type of filler better than others for this?
    • My goals for it atm are to get it registered, respray and some mild power gains eventually... I picked up the car from an elderly gentleman near the border of NSW and VIC, its honestly a bit rough and looks like its been driven on a farm (because there was so much dirt underneath). Last week I dropped the subframe and emptied the old fuel out + added a new fuel pump (think the old one went bad from old fuel). Now I'm onto fixing a coolant leak at the rear of the engine + adding a new radiator as the old one is corroded. After that i have a new bumper, coils (as the old were leaking) and lots more
    • Welcome buddy! Plenty on here and YouTube. What are your plans for it? Good luck with the Rwc and Rego bud!
    • Love this so much! Please post a photo when you have a bike on the trailer.  I was a little bit worried about having a tow bar on the Skyline, but having it hidden behind the number plate is genius
