bomex is nice and thats what i planned on getting but i rather get top secret front with impul sides and not sure about the back yet. bomex is too extreme
i only ask because my friend just bought a kit for her r34 and she got the cwest front which she ordered wrong. i think the front is ugly and just wanted to see what you guys think of it
any ideas for what back to get?? lol
Edited by R34P3R
depends how you want to look... maybe i want my car to look scary but solid hence the URAS, something you have obviously expressed to me that you dislike with a passion but that's fine, it's not your thing...
anyway, Bomex is for the stylish... i don't know any guys with the Bomex front, only chicks ie. Erin [ANAHERA] and Kelly [sNIP3R] awesome for chicks, for d*cks i'm still unsure, but that guy that bought Erin's car is a tool anyway
Leo's combo is quite popular, Do-Luck with Bomex and Bomex and Ryan's has turned out awesome with Do-Luck and Impul and Impul... the Impul is nice and subtle works out well...
C-West is average in my opinion, depends what kind of style you're after as all the different kits mentioned in this thread are quite distinctive and none are similar to the others
my2c Sunny
ive seen bomex kitted white r34 driven by africans [ im not being raciest, there no other way to say it]. i like the extreme look but i dont want it.
on car mate there is 2 ts style kits. ones the proper top secret one and the other is more of a z tuned look. any one know what it is?
my2c Sunny
I dont mind eriks old car
-Top Secret copy front bar
-Bomex sideskirts
-Phoenix rear pods
-Original wing with Nismo base stands
as you can see m8 everyones different get what you like.
I would advise searching this website as there are alot of topics on r34 kits and you will see many photos.
Use google too
Then after you have spent extensive time on finding one that you really like, purchase one and make sure you get a quality fit.
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
    • The log you did with ECU voltage, can you log the other things too like rpm and oil pressure? Need all that info together to compare easily
    • Editting as I hit post to soon, and this will lock out otherwise.
