Im trying to organise compliance for my next car but im having the biggest issue with all these compliance centers!
Its driving me crazy. The car is an R32 GTR, its a 1991 model, (before anyone says anything about not being able to comply the vehicle because of its year, I can because it was produced in early January so it can be complianced.) Anyway, because its a 91 model, the car dosnt have side intrution bars in the doors. Some places tell me it dosnt need them and some do..i cant seem to get a correct answer from anyone!
If my dad was around id ask him coz he would know but he isnt. Has anyone ever imported an R32 91 model and needed to get the intruion bars in or not?
One of the compliance centers told me its best if I just get new doors for the car, the 92-94 models already have the intrution bars installed from factory, maybe thats the best option, but b4 i start buying parts for the car I wana know if anyone else has ever had this issue?
-Ferah
https://www.sau.com.au/forums/topic/252302-side-intrution-bars-on-an-r32-gtr/
From as much as i know every import without them, needs to have them fitted.
Mine didnt come factory (87) and i had to have them done, in both my HR31's actually now i think about it, id imagine a GTR to be no difference.
It would be easier changing the doors and faster, just depends on colour matching
What compliance places have you spoken too?
your probably right, but iv never had an issues with compliancing cars coz iv never had anything under a 97 model, so I wouldnt know as this is my first experience with an older car. Iv spoken to heaps of places..
heres the list lol..
Jap Cars
Transcar
Raw Performance
Sumo Performace Center
Spec R Engineering
Kamikazi Motors
two of the places were really helpfull...but none of them can seem to give me a proper answer, thats why I ask if anyone has ever come accross this issue
I'm from Spec R Engineering, basically as a general rule any RAWS car must have either factory fitted intrusion bars that pass ADR 29 or the RAWS workshop must hold evidence for fitting aftermarket ones. so it will all depend on the evidence the workshop have
I remember there was the SEVS Law, 15 year old car rule.
What can be imported under the 15 year rule ?
Anything as long as it is older than December 1988. Also, there are still a handful of 1989 / 90 models listed in stock which have import approvals issued under the 15 year rule before it changed last year, and these can still be imported under this rule.
Registration of 15 year old cars
We always suggest with 15 year old vehicles that an allowance of about $1,200 be made for the modifications required prior to registration (which can be done by anyone). These vary from vehicle to vehicle and State to State, and may include the following items:
o Seatbelts
o Sun visors
o Child restraint points on the rear parcel shelf
o High level brake light
o Catalytic convertor
o Driver's side mirror changed from convex to flat
o Unleaded fuel filler opening restrictor
o Side intrusion bars
o Dash dimmer switch
o Engineer's sign-off (some States only)
If you are uncertain about what needs to be done for a vehicle you are considering, you should ask the registration authority in your State for further information. Costs of the work can then be determined by contacting a workshop prior to going ahead. While you can make all the changes yourself, we can of course recommend a reliable workshop in your State should you require assistance.
Performance modifications
15 year old cars with performance modifications simply need to get through your State's registration process.
The 15 year rule is separate to the new import scheme (SEVS) so there is no need to remove performance modifications for "compliance".
However, each State has it's own rules on what level of modifications are acceptable, so you should check with your State's registration authority if you are unsure. For example, in SA which is the strictest State, any vehicle must be completely stock standard when registered except for wheels which can be aftermarket (but no more than one or two inches larger than factory).
- http://www.prestigemotorsport.com.au/modul...rticle.php?t=11
I got my compliancing done at Carizma International, so ask David who is a member on SAU and see if the rule applies to you and he can let you know if it needs to be done...
Cheers, mate,
yeah, our workshop is Raw Performance Imports, she called us I believe.
15 year rule is now pre-1989 rule, so cars have to be before 1989 to fall under this rule.
Good luck with your compliance quest DNGRUS, give us a call if you have any other questions!
Cheers,
David @ Carizma
Cheers, mate,
Cheers,
David @ Carizma
:D
So... Meaning Ferah will NOT need intrusion bars?
But its safe to have it right?
needs intrusion bars....i used to work for a few engineers and fitted them all the time...easy job....no problems....just make sure you get a nice job as ive seen heaps of butchered cars due to bars being roughly fitted
Hey, sorry for the confusion. No, she is still importing under the SEVS scheme, which is different than the pre-89 scheme. The rules you quoted still apply for the pre-89 scheme, and side intrusion bars still apply for both schemes as well.
cheers,
David @ Carizma
:D
That's a good idea....I'd still recommend side intrusion bars for safety reasons though, especially on an R32 GTR.
Remember, there's a reason why the government require them, and it's not for looks.
ok thnks for all ur help :P
Iv decided to swap my doors with my bf's R32 for the compliance lol
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
