i am getting some vibration at about 2000rpm at move off for couple of seconds and then it stops. basically when i am driving it seems like its coming from directly under the handbrake.
i have changed the cross and bearings and the centre line rubber/damper/bearings. Dont know if the replaced rubber was faulty or there is some other problem.
anyone that has experienced this and can give me some ideas as to what i can do to stop this?
https://www.sau.com.au/forums/topic/252312-r32-drive-shaft-vibration/
What car is this for?
I have a similar problem on my GTS4. ws told it was a rooted transfer box.
Could be unbalanced driveshaft.. But I have heard this is quite rare unless something has hit it and it has moved recently
Is this only in 1st gear at 2000rpm or all gears at 2000rpm.
If it's only in first, what speed is it at?
Is the clutch fully out?
A vibration froma drive shaft is very rare, unless serious damage was done to the car, example drifted into a gutter or the like. I put the entire left side of my car into a guard rail at 100km/h, walk-away accident, had the car repaired, and I am still driving on the same shafts, no damage to the drive line at all other than suspension.
What type of car is it, a GTS4 or a GTR?
B.
if it's only during take-off and never any other time (example, hard change from 1st to 2nd), chances are you might have a warped fly-wheel shuddering as the clutch comes into contact with it.
If it's the tail-shaft bouncing due to the worn rubber, then you would also have the issue in all other gear changes as well, due to the gearbox changing force on the shaft.
B.
B.
well in observing why i picked the rubber
in any gear at that slow speed it would happen but i guess the faster the shaft is spinning the more it gets in unicy or spinning on the dime. at very high high speeds i can feel a little little bit of it happening
on the other hand i took off the centre line rubber and filled it with urethane and the vibration got very rigid not only at low rpm and speed but for even higher speeds and rpm until i go very fast.
You've had all the universals, centre bearing and centre bearing support rubber replaced?
The stock uni's are peened in, so all this work must have been done by a driveline workshop?
Since all the obvious items have been replaced, presumably by professionals who will have also done a full shaft balance, the only thing left is they may have bolted the centre uni out of phase with the front when bolting the 2-piece shaft together.
Worth checking your gearbox mount too.
when you say out of phase with the front your talking when putting the small piece of shaft back to the longer piece? if so isnt the holes peered together to fit?
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
