Due to the dollar vs yen issue we have at the moment the JUN and Tomei pumps are getting frightfully expensive. The option to go with an externally driven oiling system is getting more cost effective. Im looking into a group buy to get kits locally manufactured using a single stage gilmer belt driven Peterson oil pump. These kits will have all the necessary fittings, brackets etc as well as instructions for ease of installation. The will be produced by Mark Jacobsen from Godzilla Motorsport and have been proven and tested on his drag car as well as RH9 R34 GTR which makes 1200+hp at all four wheels. Kits are being priced at the moment and im looking for expressions of interest from the forum to see if it can be produced at a reasonable rate if 5 or more people are willing to purchase.
1/DiRTgarage
https://www.sau.com.au/forums/topic/252332-rb-external-oil-pump-kits/
  • Replies 80
That's about on the money for a full setup. That would include all the -12 Speedflow and braid as well as the filters, pickup, brackets, crank bolt, pulleys etc too.
Nice to have this as an off-the-shelf kit for people to buy instead of wasting their money on remanufactured OEM shit.
OS i knew you would be in on this mate...lol
righteo...expressions of interest so far are
1/ DiRTgarage
2/ Charlie
3/ N1GTR x 2
4/ stylz7 x 2
5/ CSNet
6/ OS30GK
thats 8 so i might look at getting a price to get 5 supplied and another for 10. As 10 would make them cheaper again.
Will it work with my trust sump or would it need a new sump? When does this group buy end? Down the road how easily is the converted or upgraded (Dry sump?) Would this be a good setup for a track orientated GTR? thanks
No it will work with existing sump whether it be stock, Trust, Hi Octane, Hi Energy etc...
Im still very new to the external set-ups, very interested.. My build is looking like a N1 pump, stock sump (jun baffles), orifice and drain.
Could someone point me in the right direction on what I would need to make this set-up effective, this kit gives me everything I need to run dry sump?
Tomek
Edited by Tomek
Would this go in place of the Air Con pump or would it be possible to keep it? If this is possible then I'm interested.
is this your car or your mums?
real cars have no air-con!
Guest
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
