The pump will flow more than enough for whatever any of you need. The gears on the front of the crank pulley and the pump govern the speed of the pump. You'll generally drive the pump at half engine speed but I know Mark has a pretty good idea about where he likes the ratio to be.
Tomek - this is NOT a dry sump pump. It is an external wet sump pump.
All - yes air con is gay.
  • Replies 80
is this your car or your mums?
real cars have no air-con!
So are you going to answer the question or not?
This is not a full time dedicated track car yet! (working towards it).
I am already stupid enough to run around playing sport in the heat, doesn't mean I have to drive in it too after being in it all day. :)
I don't understand what specs you need.
Exactly...Mark has set two of these up....one is on his 7.84 R32 second race car....the other on his 1500hp dyno R34...you wont need to worry about what it flows etc...they will be a bolt up item that all the headwork has been done for you on it already. This set-up has been ran and tested on Australia's most powerful GTR's over the last 3+years.
They will be easy to install with all fittings and instructions and now no need to run an oil drive collar on your crank.
And they work.
easy
Edited by DiRTgarage
dunno how ur gonna use them with a std sump or a non modifed sump, caus they generally need an external pickup welded into the sump. Well u could weld a fitting onto the pickup side of a std pump, but not ideal IMO
also paul, for ease, you may want to try to sell ati balancers with them and their crank snout pulleys or its gonna be a pain to acoomodate everyone with their different balancers.
its possible to retain aricon etc, jsut make up an l-bracket and mount the pump under the alternator
i'll edit this tomororw with some pics after i put the sump on
Glad to see that Mark is finally releasing these to the public :)
For anyone with big power engines, these are an excellent choice in order to avoid the dreaded RB26 Busted/Broken Oil Pump (BOP) syndrome. Yes, even the JUN pumps are prone to the BOP syndrome.
oh ... :D should learn to read thread titles properly :(
Still interested thought.. Need to do some reading first thought ..
What happens to the regular off crank pump, im stumped.. works in succession at high revs, obviously.. like I said stumped.. :huh:
Have a look at the pics I posted and you'll see the feed from the new pickup in the sump pan. Here is a pic of a gutted standard pump with block-off.
****PLEASE NOTE****
This is just how I did it. I am not part of this group buy and I'm just trying to help Paul/Mark/The-Rest-Of-You out with some visuals.
the original pick-up is used and the existing oil pump is internally grub screwed and the 'guts' removed. The fittings are attached to the original pump where the welsh plugs are on it (if you have access to a pump you will see what i mean). We are looking at sourcing some 'busted' oil pumps and already modifing them as part of the group buy for ease of fitting. This will make it a truely bolt on proposition.
Thanks, would be good to see how you did it
Interested at this stage as well.
Whats the biggest advantage i am getting with this set up over the normal oil pump and crank collar set up?
Because it bolts onto a/c bracket, will it fit a 30 block?
Approx time frame? Anything a little more concrete on pricing?
Cheer Chris.
Cheer Chris.
yes it will be a while until all suppliers get back with exact costings. and final details...maybe 1 week...will fit your RB30.
Will fit an rb30 indeed. This one is on a 26/30 for a gtr.
Currently waiting on the crank snout to be machined b4 everything can be finished on it
Paul, if u want the cad files for the bracket let me know. Alternatively i can get a hole heap lasercut and send them down.
your bracket looks the goods and maybe the go as a lot of people will want to retain a/c. Might go that way or have both brackets available and then people can mount them where it suits them best. Ill be putting mine where the a/c went as i have plenty of room there and would 'even' things out a little in regards to room/space etc.
thanks for your input
    • In a few years from now, you'll regret that. It'll eat away at you, knowing the truth of the ugly hiding beneath the beautiful exterior... 😛
    • I don't think the G2 profile is particularly dangerous for the engine per se, more just are you actually ok with the turbo lag trade-offs? If the answer is yes then go for it. I personally don't think I'd be ok with it because I spend so much time at lower RPMs and I really enjoy the feeling of being able to stay in 5th gear on the highway and just roll into the throttle to get boost. Or staying in 3rd gear on "gentle canyon cruises" without feeling the turbo lag too badly. The 525 pump should be able to run flat out on factory lines but I would bet the pressure drop from pump to regulator is quite impressive. I don't know how much it would be exactly but I've seen figures like 30 psi thrown around.
    • It's interesting seeing everyone talk about what level of risk they are happy to tolerate.  Building a GTR always has a level of risk, you could be that lucky guy that drops 20k on the engine build alone and still has the thing go pop on the dyno. Life is fun like that.  The way I see it, the thing is a toy to be enjoyed. I'd be happy to turn up the power on stock motor and limit the risk with sensible tuning and engine protection. If it still goes pop, it is what it is. The car isn't a daily driver so it can happily sit while a plan is made to sort it out.  Given this thing will be a street car only, I really feel it's worth the (relatively small if managed well) risk to turn the power up to around 350KW on e85.  I don't think anyone getting into the skyline game now is doing it out of logic. Surely it is a purely emotional decision so I'm not sure how important it is to think about the engine build logically. The heart wants what it wants.  @joshuaho96 little note for Josh, I run my 525 pump flat out all the time and through the factory lines without any issues. (excluding the melting connectors, that's sorted now. we'll pretend it never happened lol)
    • But the Nexus S3 is very expensive and won't be as purpose-built for the application as a separate electronic boost controller :^) More seriously my pet issue here would be that the Walbro 525 running at 100% duty cycle is going to require more FPR than the stock setup can handle. I'm also pretty sure from what I've seen elsewhere you might want to slow down the pump regardless unless you're going to come up with some way of upsizing the fuel lines coming from the fuel tank. Factory 8mm fuel line doesn't actually flow very much if you want to keep pressure drop down between the fuel pump outlet and FPR. If you really want to "keep it simple" I would run only as much pump as you need and source a fuel pump controller to slow down the pump in the vain hope of being able to run stock-style FPRs which are pretty dinky. Or just use the HICAS lines and it should be mostly fine. OP should also really think hard about what profile they'd want out of the turbo. My pet choice here would be the G1 profile rather than anything higher power but YMMV. I already think ~stock turbo lag is pretty bad so I don't want to make it worse. In "gentle canyon cruising" I found that I spent a lot of time around 4-4.5k RPM. I also recommend DIYing labor if you're detail-oriented enough. Costs are high for labor + if you do it yourself you can be your own quality control.
    • GTSBoy is again on the money. My actual advice? Sell the car. (really). For what it's worth as is, you can sidegrade into something much better. If you care about function then this is the actual move. If you want a Skyline to perform, set aside about $100K to do it. This is NOT a typo. You will see right away these are two very different mindsets. Realistically we're talking full restomod for any Skyline still kicking around. Have an honest think about which one you are.. and what you want to do, and how much you want to invest in this (with no return).
