The pump will flow more than enough for whatever any of you need. The gears on the front of the crank pulley and the pump govern the speed of the pump. You'll generally drive the pump at half engine speed but I know Mark has a pretty good idea about where he likes the ratio to be.
Tomek - this is NOT a dry sump pump. It is an external wet sump pump.
All - yes air con is gay.
  • Replies 80
is this your car or your mums?
real cars have no air-con!
So are you going to answer the question or not?
This is not a full time dedicated track car yet! (working towards it).
I am already stupid enough to run around playing sport in the heat, doesn't mean I have to drive in it too after being in it all day. :)
I don't understand what specs you need.
Exactly...Mark has set two of these up....one is on his 7.84 R32 second race car....the other on his 1500hp dyno R34...you wont need to worry about what it flows etc...they will be a bolt up item that all the headwork has been done for you on it already. This set-up has been ran and tested on Australia's most powerful GTR's over the last 3+years.
They will be easy to install with all fittings and instructions and now no need to run an oil drive collar on your crank.
And they work.
easy
Edited by DiRTgarage
dunno how ur gonna use them with a std sump or a non modifed sump, caus they generally need an external pickup welded into the sump. Well u could weld a fitting onto the pickup side of a std pump, but not ideal IMO
also paul, for ease, you may want to try to sell ati balancers with them and their crank snout pulleys or its gonna be a pain to acoomodate everyone with their different balancers.
its possible to retain aricon etc, jsut make up an l-bracket and mount the pump under the alternator
i'll edit this tomororw with some pics after i put the sump on
Glad to see that Mark is finally releasing these to the public :)
For anyone with big power engines, these are an excellent choice in order to avoid the dreaded RB26 Busted/Broken Oil Pump (BOP) syndrome. Yes, even the JUN pumps are prone to the BOP syndrome.
oh ... :D should learn to read thread titles properly :(
Still interested thought.. Need to do some reading first thought ..
What happens to the regular off crank pump, im stumped.. works in succession at high revs, obviously.. like I said stumped.. :huh:
Have a look at the pics I posted and you'll see the feed from the new pickup in the sump pan. Here is a pic of a gutted standard pump with block-off.
****PLEASE NOTE****
This is just how I did it. I am not part of this group buy and I'm just trying to help Paul/Mark/The-Rest-Of-You out with some visuals.
the original pick-up is used and the existing oil pump is internally grub screwed and the 'guts' removed. The fittings are attached to the original pump where the welsh plugs are on it (if you have access to a pump you will see what i mean). We are looking at sourcing some 'busted' oil pumps and already modifing them as part of the group buy for ease of fitting. This will make it a truely bolt on proposition.
Thanks, would be good to see how you did it
Interested at this stage as well.
Whats the biggest advantage i am getting with this set up over the normal oil pump and crank collar set up?
Because it bolts onto a/c bracket, will it fit a 30 block?
Approx time frame? Anything a little more concrete on pricing?
Cheer Chris.
Cheer Chris.
yes it will be a while until all suppliers get back with exact costings. and final details...maybe 1 week...will fit your RB30.
Will fit an rb30 indeed. This one is on a 26/30 for a gtr.
Currently waiting on the crank snout to be machined b4 everything can be finished on it
Paul, if u want the cad files for the bracket let me know. Alternatively i can get a hole heap lasercut and send them down.
your bracket looks the goods and maybe the go as a lot of people will want to retain a/c. Might go that way or have both brackets available and then people can mount them where it suits them best. Ill be putting mine where the a/c went as i have plenty of room there and would 'even' things out a little in regards to room/space etc.
thanks for your input
    • Right, its been a while for updating this car, but I made some small but important progress today. In the end I bought an Ecutek dongle from the Australian distributor Tunehouse (for local hardware support) but have gone with a remote tune from Racebox in the US (because they have done millions of these, and I could not find any tuner where I could access the tune anyway as they are all password locked). The App is reasonably easy to work with, but the PC software reminds me of Haltech's ECU Manager that you need to use with the Plat Pro ECUs, it is a nightmare.  Anyway, I sent the details over, got back a tune file and a request for data logs. I finally got a chance to access a private test track today as they want redline logs in 3rd and 4th, and have sent them back for the first round of reviews. The main difference in the tune is going from 1.0 (stock) to 1.3 bar (19psi), although I'm sure is a lot of other stuff in the background. Keeping in mind this is a dead stock car with 125,000klm, this is what the App's performance test claimed: Before After Interesting to note that both 400m tests had the same terminal speed (158klm/h) but different ETs. And no, the speed limiter seems to be higher than that at 186kl/h. Summary of the key logged parameters for the 3rd and 4th gear runs were: Those little turbos were certainly whizzing at 200,000rpm+.  Also I'm really not that excited about oil pressure 55psi at redline so I think I'll go thicker than 5w30 (nissan recommend 0w20....) and see if that improves it. Other than that (and the big boost spike....) everything looks good as a start to me.
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 🙂
    • After drying a few days, time to put her back together
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
