  • Replies 80
Shit, and here i am at home with two used Jun pumps.. i wouldnt mind this option, but considering i was going to do drysump later on i may give it a miss..
i'll keep watching how its going just incase!!
Put me down as a definate :)... F#ck paying $2400+ for a tomei pump and still be worrying.
Hopefully this buy starts sooner rather then later.
Few q.
-Stock capacity sump vs larger? much diference?
-Baffling?
Tomek
Few q.
-Baffling?
2nd that :thumbsup:
I would recommend a larger sump with baffles for this as it still uses the stock pickup although modified for the external pump.
What you need to remember is that this is replacing the crank driven pump, so will help with the known weakness of cracking the drive on the internal oil pumps.
The more oil that you have in the sump the better.
I am having a guess but you should still do the other mods for oil control to the head (i.e. restrictor).
