factory wheels are 17x7.5 +40
so 18x9.5 +35 is the widest you'd wanna go for the rears and that WILL be sticking out a little bit from under the guards but not too much. Don't go 9.5 fronts that will look just lame and could get you busted, 8.5" fronts looks good.
Edited by Delta Force
Use this calculator ..it shows you exactly what will happen with new rim size and offset.
http://www.1010tires.com/WheelOffsetCalculator.asp
And this is what 18x9.5 +35 looks on a GTT
http://www.skylinesaustralia.com/forums/po...-287-131149.jpg
And just another quick note ... do not go below offset of +28 as that will make your wheeltrack illegal and your car's suspension etc will suffer.
and to answer your original question, if you use the calculator, you'll notice that 18x9.5+30 will give you an extra 5mm inner clearance but 5mm outside width than +35 ie. the rubber will stick out 0.5cm more than on the one pictured above which I think is pushing it as it is.
18x9.5 +27 (235/45)
18x9 + 14 (225/45)
on my r34, had to roll the rear 1/4s.
i put the 9.5 at the front cause the 9" stuck out so i swapped them around.
the 9" fits perfect on the back anyway due to the offset, might throw in a 5mm slip on spacer to make it right up against the guard.
    • There's a fair chance that my bushes are Nismo, because I'm reasonably sure that when asked the question (when putting the subframe into the car in ~2012) "What bushes do you want to run?", I'm pretty sure I would have answered "The stiff ones!". I had to put some silicone grease onto the GKTech inserts I jammed into them last week, because the bushes were quite resistant to having something jammed up their jacksies. So, I reckon you'll be best off doing Nismo + inserts. And, if I'd known you had PU bushes in the subframe AND PU pineapples, I perhaps would have said earlier that that's probably not a good idea. The pineapples are only intended to work with the stock type bushes, because those have a crush tube (which is what makes it end up looking like there is sloppy space in there - but doesn't, because the crush tube does make contact steel to steel) and the pineapples live in the space between the subframe's outer tube and the lower washer/bracket. But the PU bushes don't leave the space in the same way that the stock format ones do, and they do end up fighting for space. Order some bushes and collars and get to it.
    • Thats the current state of the reo. Bit ew, but GTR Reo and supporting bars are $2000, and 2nd hand GTT ones are $1000... More engine disassembly. The good news is   Various LS weird sounds are apparently normal Everything coming out is in perfect condition The bad news is: Everything coming out is in perfect condition It looks like whoever assembled this engine ~25,000km ago was telling the truth with what's in it and how they did it. Even things I was unsure of like the timing chain - But it's a brand new double row timing chain, spaced perfectly. They even cut up the stock windage tray to keep it instead of being lazy and to work with the baffle. Cam, Heads, springs, LS7 lifters, Pushrods - All look new and have obviously been working perfectly. In other news, we removed the pineapples that were loaded below the superpro subframe bushes. They look a fair bit munted and have deformed the poly bushes that are 'above' them. I'm telling myself that now that there's space 'under' the bush between the little cup that bolts in... that having a pineapple wedged there was bad and basically made the rear end solid. The pineapple and the superpro bush are ... equally deformed (i.e they have deformed one another from being smashed together). We'll see how it goes with bushes only. I am sure this cope will fail and the answer will be to drop the subframe and put nismo rubber bushes in there instead. $400 worth of gaskets and ARP head bolts to replace perfectly new looking gaskets that absolutely weren't leaking  and were installed perfectly with great care - because god damnit.
    • Why bother? Keep them under 1bar and be happy, I had it for 10 years and never had an issue. once you go beyond that the budget blows out fast and then keeps on blowing out
    • I'd still recommend rebuilding the turbos too. That will eat up a lot of the budget especially if you aren't willing to put in the labor to R&R the turbos yourself but it's a huge risk to ignore it at this point.
    • Can't help it, its an illness.
