Hey guys, i am soon getting a remap for my r32 with an rb25 neo in it. I am running the typical mods (3" exhaust, Fmic, standard rb25 turbo, metal intake, boost controller, bosch 040 pump)
I bought an already remapped computer (rb20 ecu remapped for an rb25, making 209kw atw with same mods as above on 10psi) which means that it is NOT remapped for VCT. I havent yet put it on my car and i am currently running the R34 Neo rb25 computer, which has not yet been tuned.
If when i use the remapped ecu, will a set of rb25de cams be of any benefit? will they even be able to work if i disconnect the vct? or should i ditch the remapped ecu and see if i can get the rb25 ecu remapped and run the vct?
I am guessing that i can't have the best of both worlds though.. as in: remap the rb25 ecu with vct and still run the cams...
THEN ... will i need to run adjustable cam gears?
Any ideas/ thoughts appreciated or if you have personally done this mod what were your results (even on an s1 rb25)
Cheers, Reece
https://www.sau.com.au/forums/topic/252415-rb25de-cams-in-rb25det-neo/
