Hey people am having some dramas with my R32 GTR:
I had a go at cleaning my engine bay the other day as the car has been off the road for the last year +, all went good so I decided to give it a bit better clean today.
I alfoiled up some electrical bits WP40 others and then went about degreasing the left-handside of the engine bay and then spraying scrubing etc
When I started the car up it blew out a lot of what looked like water out the exhaust?
The car idled very rough and when given acceleration sounded very hollow, backing off the acceleration the car would drop to around 300rpm and them slowly and sparatically make ts way back to 1100rpm.
I then took the car for a short drive - it had trouble taking off and then a complete loss of power and started blowing blue smoke - i took it straight back to the shed where i kept it idling for around half an hour or so.
The car kept engaging "clicking" something that would drop idle rpm and then slowly work its way back up to normal rpms!
The car stopped doing this after 20 odd minutes but any time i tried to drive it - would blow blue smoke and loose all power?
(The car hasnt been driven much in the last year but had it running perfectly and took for a decent drive about two weeks ago after I got it back from panel and paint)
(Also having a small fuel relay issue which means the fuel pump is earthed engaging as soon as ignition is switched cant see how that could have anything to do with it though???
Any ideas or advice would be greatly appreciated????
Thanks,
Dan
When you said you haven't started up the car in a year... did you simply wash the engine bay and then start up the car for the very first time in a year without manually cranking over the engine to build oil pressure?
Or did you do all of this before you washed the engine bay?
Nah this was all done weeks ago and had the car running smick around 2 weeks ago where everything was checked and took it for a decent run!
Am going to take coils / plugs out and see if i can find any moisture then i guess i will start with electronics?
that sounds like moisture/water in the coil packs. I had the same thing when i had an sr20. Try getting an air pressure hose and dry the coils (if there is water/moisture there)
Yeh took colpack cover off today and the first three plugs were caked with water so have cleaned area out, cleaned plugs and dried coils. The car is definitely running better but still has loss of power no boost and blowing a lot of white smoke/oil out the exhaust?
Bit stumped now as to what could be making it burn oil?
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
