im looking at buying a r33gtr v-spec 95 model and i was wondering if it was still possible to cancel out the front wheel attesa system and just run rwd with a switch the same as a 32 gtr? any help on this topic would be greatly appreciated
https://www.sau.com.au/forums/topic/252442-help-r33-gtr-v-spec/
Nah dude that "switch" trick is only possible in the R32 GTR's. Not quite sure but in the R33's it means ripping a whole lotta stuff out... I have read about it but forget the details. Anyways not a simple job so i have heard. There is a topic on the forums somewhere, I will have a geez for ya.
So what exactly are you trying to do? Run the car in rear wheel drive sometimes? I believe you can disconnect something at the front and its not too hard.
After R32's the R33 and R34 run a preload on the front diff so its always a little active and you can't just flick a switch...
If you want permanent RWD don't buy a GTR.
you have to take the front drive shaft out... its easy as... we all do it for 2wd dynos... four bolts and slide it out... takes 10 mins...
or check out one of the engine manuals... aparently there is a wire under the dash you can cut...but I think then the 4wd light in your dash stays on because it thinks something is wrong.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
    • You would need to paint your hardtop again though
