  • Replies 83
Posted Images
lol, yes indeed. the phones are cool and I like being able to use one to turn down the volume on the stereo etc. while I do like the sound the speakers make and the lossles transfer of music from CD to the beosound5 HD is cool I do think we'd be 90% as happy with the bose system or even a pieced together sonos based system. I guess the upside of the BO stuff will show in 30years time when the loudspeakers are still worth $$$ and still as good as anything else out. plus they do look a bit like the daleks from doctor who which I do enjoy... :D
I know Windows XP x64 was terrible, however since Vista x64 all of the compatibility issues have been solved imho. Sure you need x64 drivers, but 64-bit drivers are abundant now with new hardware and commonly used hardware.
Windows XP x64 was a mock up by Microsoft, Vista x64 was an operating system designed to be 64-bit.
Ive been tryin to get my hands on a copy of win XP 64x ultimate for some time. It seems it was a limited release and has been used in servers (so far ive read), what exactly is so bad about it?
  • 4 months later...
So it took a year and a half (probably more because I was thinking about it for some time before I started this thread) but I've finally got it.
Big props to DivHunter for all his help and knowledge in building it.
Also to Titan for all his help and all the others who have posted with information, and experience.
I'll post some specs another time when I get a chance
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
