Hi guys - need some help please!
Just purchased a camber kit, gone to bridgestone tyre center to get them installed...the guy refused to put them in coz he said "they look weak" and there was no australian standard certificate/sticker issued with it.
I purchased the product from ebay...and the seller claims that these kits have been used in the america with no issues what so ever.
Do you guys know of any good places to get them installed and have it wheel aligned in melbourne?
(I was referred to many different wheel alignment places and they refused to do my car because "they didn't have the technology" & bridgestone was the only one that could do it)
Any advice will be great.
thanks!
https://www.sau.com.au/forums/topic/252525-camber-kit-dilemma/
From ebay? you have a what... $30k - $35k worth of car and you put your trust on some overseas seller telling you the kit that cost a couple hundred is fine and won't come loose when you're doing 110 on the freeway? if anything happen he would not have any responsibility and you'd be very unlikely be able to recover anything from him since he is not in Australia.
I'm sure they (Bridgestone) are just being safe, as if something is wrong you could put the fingers onto them arguing it was a faulty worksmanship, etc.. and they have to go through all sort of paperwork to prove otherwise... and also they DO care about your safety as by law they have a "duty of care".
There has been cases where dodgy, cheap 'camber kit / arm' actually snapped as they could be made out of the wrong material or unable to support your car's weight or the forces during cornering, or the thread just wears out prematurely.
If you still want to put it on otherwise for any reason (e.g. racing), take it to performance workshop that would normally specialising in modified cars, e.g. turbo swap, FMIC, etc, as they'll be more likely to do the job with 'non-AS / ADR approved' parts as is with all aftermarket turbo, FMIC from japan or china that are definitely not ADR approved.
Try Centreline in Thomastown or Fulchrum suspension, if not try Chasers in Dynon Rd. But I cannot guarantee that upon inspecting your camber kit they could indeed saw it just as Bridgestone saw it as 'weak' and refused to do the job. But at least you could have asked so you get a 3rd or 4th opinion... However if you're going with Centreline I would say you'd be better considering the Whiteline camber kit as Centreline is the official distributor and the Whiteline kit is an Australian product so you have some guarantee and support from local manufacturer if anything is wrong. I believe 350Z's suspension part will fit on V35.
Good advice that, spot on Rianto.
Could do a lot worse than follow that advice... and yes I think most 350Z stuff fits V35's
After reading alot about the different camber kits available for our cars, i ended up going with NAGISA AUTO suspension since they seemed to be the ones made to the best quality and jap made too
the KINETIX brand in America do not import this brand as there have been alot of complaints and accidents in America from these rear camber arms cracking and causing the car to loose control on the freeway etc. at speed and crash.
i have the nagisa auto rear camber, front camber and rear toe arms in the car right now and they all fit perfectly with no hassles.
i got mine installed at Powerplay Imports
Edited by BLISTC
I've got Nagisa Auto front camber arms, and SPC Performance rears.
SPC Performance are an American brand, but they have a really good rep. They're also about half the price of the Nagisa Auto ones.
Edited by scathing
O lucky, I nearly bought a set of those eBay ones. That's because Whiteline had no rear camber kit for V35 or Z.
But then I went to the Tyre Factory for an allignment and even though my rear seems to be squatting alot they said it was perfect and didn't need adjustment. That's Tyre Factory for ya. I might invest in thoses SCS ones and a better suspension place.
Thanks guys.
I've called Fulchrum and Centerline, and they have no such kits for the v35 nor for the 350Z. They told me to bring the car in to see if there are other bushings on the market that can also fit the v35.
see how I go when I bring it in this weekend.
Thanks guys...
I went to Centerline in Thomastown, and they said they will need to fabricate a new bushing from scratch. He didnt have any other bushings that could fit the car.
He wanted to take off the rear arm...make some measurements (which will take a day and 600 dollars in labour) have it sent to sydney, and fabricated.
Will cost another couple of hundred dollars to get the bushings made...and another few hundred to get them installed.
pretty expensive...
I will contact other suppliers mentioned in this forum, and see how i go...
once again thanks for the help
