There is a product called 'crystalite' that now has ADR approved headlight tints. Its not a film but a micro resin that bonds to the light. It is quite expensive because you can't DIY. Needs a qualified Applicator. 5 or so colours and claims to be heaps stronger than the OME light (polycarbonate lenses) surface so scratches are avoided. Tell me what you reckon? click the link!
http://www.flickr.com/photos/12281250@N02/
PS. I am considering becoming an applicator.
Edited by R34GT-T
https://www.sau.com.au/forums/topic/252545-tinted-headlights/
  • Replies 96
i have actually seen an r33 with a tinted headlights and i have to say it looks really mean and heaps better looking than the standard lights, and they look expensive i liked it, it makes the car stand out more it was at vic fawkners kfc, if this guy is here i hope he would post some photos so everyone can have a look but the car looks way better. how much do they cost?
I only have one opinion about the concept of applying a light-reducing tint to a surface designed to allow light to pass through it in order for you to see where you're going.
f**king stupid.
100 percent agree. Would have to be one of the dumbest things you could do for safe night time driving.
And i highly doubt its adr aproved
f**king stupid.
It depends on the direction in which it reduces light.
If it only reduces light going from the outside world into the housing (like a 1 way mirror only stops light passing through in 1 direction) then I reckon it's great. I've seen cars with tinted lights and it looks tough.
If it reduces both ways, I'd be inclined to agree with you.
a one/two way mirror (heard it called both) only works because it has a thin metallic film on one side that reflects light in the bright room, making the window seem like a mirror. Therefore you can't see anything in the darker room because the reflection is brighter.
there's no such thing as a material that's "one way" with light.
f**king stupid.
so you don't have tinted windows i take it?
i've noticed he does that... no offence dude, but you're running with the big boys here
I wouldn't tint my headlights if it stopped any light coming out... which is pretty much the definition of tinting...
Unless kinks is a mad hectic street drifter, he won't really be "looking where he is going" out of his side windows. Front windshield tinting is illegal, aside from the sunvisor strip at the top.
so we should ban this?
Yes. It's f**king hideous.
    • Well some mostly good news and some slight bad news.  Good news is cylinder 6 did in fact only require a honing and I'm good to run my 86.5mm pistons again. I should also get the block back by end of week. Bad news, had a few surprises pop up. First, main and rod bearings were trashed. No sign of any heat damage. I knew right away what caused this... I had not packed my oil pump originally and spent a lot more time than I would have liked cranking the motor to get oil pressure. It sounded fine once started so I chucked it up to luck and forgot about it. Luckily rod and crank are fine and just need new bearings. Engine builder agreed that this was the cause.    Another surprise that carbon covered up very well that I didn't catch, something got sucked up and went through cylinder 1, 2 and 3. Luckily this was no cause for concern, just needed a bit of cleaning up. Valves look fine but he will vacuum test the head this week to confirm. I'm presuming this was something left over from welding my intercooler piping, but we'll never know. I'm going to thoroughly reclean everything.    So all in all, happy the motor is fine, and I'll get it back much sooner than expected. I'll also be taking the time to convert my WMI system over to direct port. I'll snap some pictures of that when the parts come in.
    • I understand, thanks. Yeah I wouldn't want the car to tip over, I'll try and use the sills, I don't want to risk smashing the chassis rails. I ordered some rubber pucks that have a hopefully big enough slotting. If the front right gives me trouble I can always just make a wood block. I'll measure and inspect the sills closer once I actually take the car up. I hope so, but the rubber blocks I had in hand so far were pretty damn firm, if they are that hard they won't give much way. I'll let you know what happens. Angle grinding rubber isn't one of my favorite tasks. I'll probably start a build thread soon, for my own documentation and "log" as well as sharing what's going on with the car.
    • Kinda something I have been thinking about.  To be honest, we bought it already driving like that.  So there's no telling how long it actually has been driving like this.  Hopefully damage is too bad when we drop the pan.   I am having a hard time finding a site that sells the solenoid for the 5 speed auto, do you have any suggestions?
    • That'll be most likely down the road...  LOL
    • a stock / option or aftermarket?
