  • Replies 96
I only have one opinion about the concept of applying a light-reducing tint to a surface designed to allow light to pass through it in order for you to see where you're going.
f**king stupid.
Your statement is right but does not apply here!.......................
This product has spent many months inside the labs of University's studying the effects that it has on light passing through the tint. Each colour has been stringently tested under different environments. Each colour made available in Aus will have passed all ADR requirements. The product does not change the properties of light passing through it. They look tinted by day but look white again at night when the lights are turned on. Each car is given a certificate to show that the product used is Crystalite and is ADR compliant. This is what you show the cops when they ask. It won't be long before they are aware of the product and will know to ask you for the certification and leave you alone. They will book those using illegal means of tinting or not holding the Cert.
At least 50% of the cops have absolutely no idea about car modifications - they DO know about photoshop and that certificates can be easily forged, so even if your certificate is legit, they will probably ignore it.
On the side topic - I drove a Holden show car (V8 supercar replica) on the street once with 20% tint all round and on the front screen. Scariest drive of my life.
So it's basically another excuse for a cop to pull you over...
But then you can act like a smartarse and show them your certificate, so they will defect you for something else
I would say your driving style will attract their attention before tinted lights would.
'chubs' that car obviosly has illegal tint. Crystalite goes no where near that dark, ckeck the link in the first post.
well in that case you shouldnt be driving an illegally modded car then. ;)
Unless you're arguing that this tint does NOT reduce your headlight's light output then my response is an enthusiastic "meh".
"Looks white at night" just means the tint is colour neutral. Big deal. It's still dimmer. ADR approved or not it's still a silly idea.
Change the bulbs Einstien!
If the product is ADR approved In a lab, are your eyes going to pick up a difference? So your telling me that when you get bugs and dust on your lights you need to compulsively pull over and wash the lights? Its not a silly idea bugs would make it dull. Im not ragging on you mate you just don't get the concept is all. ;)
ok im preparing to get flamed, i saw one of the new commo ute's in the morpheous purple that had black tinted head lights, pretty sure the ones he had were illegal cause they were black, but it looked hot.
but then again guys how many fkn tools do you see that are driving around at night without realising, "oh i havnt turned my lights on yet" and yes coppers will prob hassle you for it until they learn about it
and +1 for banning saabs, i dont care for what reason just get them out of aus,
another thing ive noticed about this thread is im pretty sure everyone is focusing on the black tint, i reckon the crystal blue tint would look hot as on my black 34 and im pretty sure the cops wouldnt even think twice about any of the colours apart from the black one
Edited by s13_Skyline_inside
A lot of guys get headlight protectors for cars and then tint them black, so that might be what some ppl are seeing.
As for the pic of the GTR posted on this page, the main reason those lights don't look good tinted is cause the front of that car looks like shit.
R34GT-T, if you get it done post up pics.
I have the head training guy coming from WA to showcase the product. Anyone in Queensland that would like a look or info let me know. He is coming mid March. I will take shots of the results and put em up for you all to flame some more.. lol. If you are a car detailer / dent doctor / stripe master or window tinter then this line may interest you as an extra to your business.
To me the Crystalite Tint looks like just another cosmetic styling like when ppl put clear, LED or black tinted tail lights.
I say leave the headlights as it is, unless it allows your headlights to be brighter, if not its just a screen protector for you lenses.
But if its your car and you want to tint it then go ahead we can't stop you.
    • Everything I found online said never use it because it'll dramatically reduce belt lifespan.  No, but I have seen excessive v-belt tension cause the audible bearing noise from excessive radial load in things like alternators. So don't overdo it. Ideally you set it to manufacturer spec using a proper belt tension guage. I tried the "clicker" type gauges but those cheap things are trash. They read way too low even when you're careful.
    • This is kind of where I've ended up for the most part. It's easier for me, easier for shops that don't have to deal with my weird criteria/picky standards, etc.
    • Will do. Suprised if it's not the starter motor considering it's 30 years old. Will get a volt meter though. Battery is close to new.   Cheers for your help, always appreciated.
    • This almost never happens these days. No. Clean your battery terminals and make sure they are tight. Use sandpaper on a dowel if you have to, to get oxidation off the inside of the terminals, particularly on the -ve. Check the earth cable from battery post to chassis ground and engine ground. Make sure the contact surfaces are clean - including the threads on the bolts that anchor them - because that's where a lot of the contact occurs. Wire wheel on a drill is a good thing for this. Make sure the crimps on those cables are all sound. Assuming none of that causes an improvement: Check the battery voltage after it has been resting for a while. If it's at the lower end of the range, put it on charge for a while, then see if it will crank better.
    • I just checked my belt, it wasn't super loose but I could bend it past 90 degrees a small amount so I tightened it up and for the first time ever my car didn't crank first time, had to crank it again lol. Don't know if that was because I tightened the belt or if it's my starter motor going out (been having slow starts for some time). Coulda also been when I was recording I didn't crank the key properly and it didn't save the recording lol.   Is that a thing if you overtighten a belt it struggles to start?
