Do you have any pics of the red tint? The only one on the flicker site had all the colors on one light. Cranberry looked kind of purple, and the pink looked kind of red. Do you have anything to better display those colors? I'd like to see whatever one looks the .."redest" out of the two if possible :rofl:
Thanks
  • Replies 96
Do you have any pics of the red tint? The only one on the flicker site had all the colors on one light. Cranberry looked kind of purple, and the pink looked kind of red. Do you have anything to better display those colors? I'd like to see whatever one looks the .."redest" out of the two if possible :laugh:
Thanks
Dude your straight out of luck. ADR said NO to red and yellow on any front lights. So the company that imports the stuff don't order those colours. Pink is as good as you'll get. You colud always buy the pink seat covers and franjapani stickers to match.... :P
Dude your straight out of luck. ADR said NO to red and yellow on any front lights. So the company that imports the stuff don't order those colours. Pink is as good as you'll get. You colud always buy the pink seat covers and franjapani stickers to match.... :)
awww gay :blush: ADR suck nuts :(
so can this be done on headlights that aren't foogy or wat eva cause i want to tint mine but they are as clear as clear can be
The biggest market for the stuff around the country so far has been new cars - clear as clear can be
my opinion of it is something like black spray painted factory mags . only should really be done on $500 hacks or other budget projects or under extreme boredom .
just sreams " look at me im half arse"
LOL, the 'judge' has spoken!
  • 5 months later...
What's the benefit of doing this? I just see it as a styling mod (shit one at that); and you're just asking to be pulled over... when you're driving a Skyline you already have enough problems with the 5-0. So yeah, sad cu.nts do it. :)
Edited by RB25PWR
and at the end of the day you are reducing the output of your headlights. even if the amount is minute. i'm all for safety when it comes to visibility at night. that is why i also see tinting tail lights as one of the most stupid mods you can do
"i know, lets do something that makes it harder to tell when i am putting the brakes on so that i have more chance of someone running into the back of my car, and then giving the insurance company a reason to refuse to pay because of an illegal mod i have done to my car"
Summed up excellent
  • 2 months later...
Obviously didn't spend much time reading through the pages regarding Crystalite. This is an ADR compliant product. It does not change white light. have lab test graphs and 9 months of adr trails to prove. So it is a LEGAL mod. love it or hate it.
-----all other forms of tinted lights - and yes your dead right.
BTW It is removeable......
Edited by R34GT-T
    • Everything I found online said never use it because it'll dramatically reduce belt lifespan.  No, but I have seen excessive v-belt tension cause the audible bearing noise from excessive radial load in things like alternators. So don't overdo it. Ideally you set it to manufacturer spec using a proper belt tension guage. I tried the "clicker" type gauges but those cheap things are trash. They read way too low even when you're careful.
    • This is kind of where I've ended up for the most part. It's easier for me, easier for shops that don't have to deal with my weird criteria/picky standards, etc.
    • Will do. Suprised if it's not the starter motor considering it's 30 years old. Will get a volt meter though. Battery is close to new.   Cheers for your help, always appreciated.
    • This almost never happens these days. No. Clean your battery terminals and make sure they are tight. Use sandpaper on a dowel if you have to, to get oxidation off the inside of the terminals, particularly on the -ve. Check the earth cable from battery post to chassis ground and engine ground. Make sure the contact surfaces are clean - including the threads on the bolts that anchor them - because that's where a lot of the contact occurs. Wire wheel on a drill is a good thing for this. Make sure the crimps on those cables are all sound. Assuming none of that causes an improvement: Check the battery voltage after it has been resting for a while. If it's at the lower end of the range, put it on charge for a while, then see if it will crank better.
    • I just checked my belt, it wasn't super loose but I could bend it past 90 degrees a small amount so I tightened it up and for the first time ever my car didn't crank first time, had to crank it again lol. Don't know if that was because I tightened the belt or if it's my starter motor going out (been having slow starts for some time). Coulda also been when I was recording I didn't crank the key properly and it didn't save the recording lol.   Is that a thing if you overtighten a belt it struggles to start?
