Hey guys,
Just though id punch in some info about something to do with oil filters; ill try to explain it:
-Now when i start my car, the knocks would jump to 91-95. I though this was just the starter motor noise but just to check i disconnected my coil packs and cranked the car, yes it did repeat the 90ish knocks without the car starting so i was pretty happy that it wasnt a bad startup tune.
-I have been having an issue with drift oil filters from autobarn with my oil light staying on for 2ish seconds and pressre the same (on startup, even warm start)
This was noticed by creatd ms and myself but i though it was just the oil taking a second to pump around.
-about a week ago i changed back to coopers oil filter and now there is no knock on startup (reaches 1-2max) and my oil light turns straight off in less than a second and i get full pressure.
Coincidence??? no way as it was instant fix for my issue
Conclusion: Bad oil filter or a bad batch; either way im not happy buying a filter which 'may' be bad and potentially wreck a 10k motor.
Take this not as a discredit but simply i will not be using the drift filter again, greddy/coopers/knn for me now.
BTW the oil was 8100xcess 5w40 and 300v changed at 2000km intervals
-Johnny
https://www.sau.com.au/forums/topic/252567-knock-vs-oil-filter/
  • Replies 68
I'll take notice when there's some hard evidence about this, I use a Ryco oil filter, and my pressure light goes off straight away, and pressure always reflects whether its a hot day, car's warm etc.
Same diff using Castrol EDGE 5w30 or Motul 8100 Xcess.
Might want to check if there is an anti drain back incorporated into the filter. Some do, some don't.
Getting agricultural but the same thing happens with my dirty diesel patrol with some filters. Genuine nissan are fine and have the anti drain back.
drift oil filters? maybe they're designed to leak oil so you can get sideways more easily and the knock is your engine rattling itself to death.
coopers filters are very good quality, keep using them.
Yeah thanks man, dont worry ill keep using coopers or maybe greddy next time for a try
10k motor? when did you get a forged build... i thought it was still a stock RB26, which is worth less than half that :cool:
Cause if it was a 10k motor, you shouldn't be having any problems or using drift filters
Aha i see so if you have a 10k motor and a crappy restrictive filter with low oil pressure then it should be ok? i mean if mine blew then i would spend 10k to rebuild it.
I use Z145A has the anti drain back valve... Slight difference on start up oil pressure registering compared to the other black Ryco filters I used previously. The part number for those excapes me now. No difference on knock noticed between the two however, always sits on 1 doesnt move until I get to about 2500rpm.
Edited by MintR33
i use a z145a too... no knock
trent uses drift filters on all his built engines... wouldn't imagine that he'd be putting a part like that on unless he thought it was a good product
Genuine Nissans filters are cheap as dirt.. why would you want to settle for anything else.
Get it directly from Nissan dealer for ~$12 a piece, get 5 in 1 visit and they'll last you a while. Probabaly the cheapest part you'll ever need to replace on the car.
I got another question on oil filters. Nissan got 2 types of oil filters that can be fitted to RB-series engine. Big oil filters and small ones. They oall have the same thread. My rb20 had a big one. And an rb25 had a small one. Small one costs more. What are the benefits of running a smaller oil filter if none ?
I always thought, that the bigger the oil filter, the more oil it can hold, the better ?
Ive noticed this too mate, umm best way to think of it; smaller one would reach full pressure faster for startup but under full load/high rpm applications you would want a higher capacity as the smaller one would be the restriction.
i dont want to bag drift but itsjust 'one' bad experience can affect the reputation of the company to a small group of potential customers.
Rememmber: a good product; the customer will only tell 5 or so people about, whereas a bad product the customer will tell over 15.
Similar to 2 threads ive read on here about a certain trader SP and their bad customer service.
nissan genuine oil filter. 15208-h8911au
thats the large one
there is no difference between the large and small oil filters, they are just made to save space, but the small ones would build pressure up more.
I buy filters for my mates GTi-R powered N14 pulsar and my R34 and they both do the same job.
Also, large oil filters are made in thailand and the small ones are made in japan, this also reflects in the cost of them!
    • I think the concept is highlighting the various scenarios where thicker oil helps, and thicker oil potentially doesn't help and only generates heat and costs power, in turn for safety which isn't actually any safer (unless you're going real hot). If anything this does highlight why throwing Castrol 10w-60 for your track days is always a solid, safe bet.
    • Jason should have shown a real viscosity vs temp chart. All the grades have very little viscosity difference at full operating temperature.
    • Oops... I meant to include the connector  view... BR/W - power from fuse L/W - motor negative to fan control amp (and off to HVAC pin19) OR/B - PWM signal (from HVAC pin20) B --  ground
    • Yep, if you are applying filler it sounds like there is something wrong with the body lol. Safe to assume there is going to be a lot of sanding going on if your still applying fillers.  Picture a perfect bare metal panel, smooth as glass. You lay down your primer, it's perfect. (why are you going to sand it?) You lay down the colour and clear, it's perfect. No sanding at all took place and you've got a perfectly finished panel.  You won't be chasing your tail, sounds like you were prepping to start laying filler. If your happy with the body after the sanding, there is some bare metal exposed and some areas with primer, no issues at all, start laying the filler. You are safe to lay filler on bare metal or primer (of course check your technical data sheet as usual for what your filler is happy to adhere to).  This isn't a 100% correct statement. There is primer that is happy to adhere to smooth bare metal. There are fillers that are happy to adhere to smooth bare metal. Just make sure you're using the right materials for the job.  Typically if you are using filler, you would go primer, colour and clear. I've never seen any instances before where someone has laid colour over body filler (maybe this happens, but I haven't seen it before). So your plan sounds pretty normal to me.
    • I don't think there's any way someone is push starting this car.. I honestly can barely move it, and moving it and steering it is just flat out not possible. I'm sure it is, but needs a bigger man than me. I have a refurbished starter now. The starter man was quite clear and consise showing me how nothing inside a starter really should contribute to slow cranking, and turned out that for the most part... my starter was entirely fine. Still, some of the wear items were replaced and luckily it didn't show any signs of getting too hot, being unfit for use, etc. Which is 'good'. I also noticed the starter definitely sounded different, which is a bit odd considering nothing should have really changed there.... Removed and refit, and we'll pretend one of the manifold bolts didn't fully tighten up and is only "pretty" tight. GM only wants 18ft/lb anyway. I also found a way to properly get my analog wideband reading very slightly leaner than the serial wideband. There's Greg related reasons for this. The serial output is the absolute source of truth, but it is a total asshole to actually stay connected and needs a laptop. The analog input does not, and works with standalone datalogging. Previously the analog input read slightly richer, but if I am aiming at 12.7 I do not want one of the widebands to be saying 12.7 when the source of truth is 13.0. Now the source of truth will be 12.65 and the Analog Wideband will read 12.7. So when I tune to 12.7 it'll be ever so slightly safer. While messing with all of this and idling extensively I can confirm my car seems to restart better while hot now. I did add an old Skyline battery cable between the head and the body though, though now I really realise I should have chosen the frame. Maybe that's a future job. The internet would have you believe that this is caused by bad grounds. In finding out where my grounds actually were I found out the engine bay battery post actually goes to the engine, as well as a seperate one (from the post) to the body of the car. So now there's a third one making the Grounding Triangle which is now a thing. I also from extensive idling have this graph. Temperature (°C) Voltage (V) 85 1.59 80 1.74 75 1.94 70 2.1 65 2.33 60 2.56 55 2.78 50 2.98 45 3.23 40 3.51 35 3.75 30 4.00   Plotted it looks like this. Which is actually... pretty linear? I have not actually put the formula into HPTuners. I will have to re-engage brain and/or re-engage the people who wanted more data to magically do it for me. Tune should be good for the 30th!
