Video Cameras For Motorsport Use
Roy
Nooby here...
Whats the best recommendation for budget smart people?
Can we have this as a sticky, but with say, proven good cameras for the money?
Oh, and how does everyone mount them?
budget option is a mini DV cam or just some kind of handy cam type camera with standard mount fitted to a roll cage mount or suction mount (not really an option for the handy cams though).
after that I'd go for a used POV 1 or 1.5. they are super reliable, easy to use and give great results and with a cheap external mic give good audio too.
mounting wise I always use a roll cage mount even with the small light POV camera heads but for a system like them with the small remote camera head you can get away with suction mount too.
Thanks for the replies.
What if I don't have a cage and am just tracking my road car? Don't really ike the idea of head cameras cause they'll shake all over the place, no?
Suction mount - goes on the glass?
Am looking at racerecall right now :thumbsup:
why not got just a handy cam with HD and flash/sd card recorder (rather then the HD recorder type ones cause of the vibrations). they are cheap, reliable and avaiable at most major appliance stores.
The len's are excelent and you can use them to tape you kids birthday party as well.
Honestly, I'm most concerned about mounting it.
Don't really want it on the dash, rather middle of the car so I can see mistakes in driving etc, but still want to view the road.
I don't mean a camera you put on your head. I mean camera set-ups with the camera head seperate from the recorder. like a VIO POV. I would look at one of those. lots of support, easy to use and great footage. you can pick up a used one on ebay for reasonable money these days.
Not sure if I have posted here or not, but I use a cheap handycam (tape) mounted to the parcel shelf. I just made up a central mount that fits using the babyseat mounting points, fit the camera to that and away I went. Captures a full view out of the windscreen and down to the gear lever I can watch any missed changes :)
  • 2 months later...
Looks like Mark is trying to temp us away from POVs to Radcam....
A RadCam for only $399!
Trade In Your Working POV 1 or 1.5
and Get $200 cash-back on a RadCam HDPro*
So Mark.....the POV has treated me well over the years....is the radcam going to be as simple and reliable?
I used a Radcam all Targa, didn't have any issues. Never used a pov, but I can't see it would have been much easier than turning it on and hitting the record button.
Everything needs an initial charge... Found it easier than a pov personally.
What did you guys have the EV (exposure value) on? I went with -1.0 as recommended in the manual (and Sunny) but found it blacked out the dash too much.
First experience was a good one though and the image quality is great, Should have some footage on YouTube soon from some of the 'ahem' "Good" stages we did in yesterdays rally.
apparently running a redcam on dirt makes you roll. I lent mine to Mark and Jason yesterday, and they rolled too.
I didn't touch any settings in mine, i've just run it as I recieved it
one key thing that anoyed me about the rad cam was the fact that when it shows battery being 2 thirds full its really about to run out. we found that it would turn off at low battery. id go to turn it off at the end of the stage and realise it had turned its self off. id then turn it on and it would show battery 2 thirds full. change the battery and it was good to go. we over come this by running the in car charger and interchanging the battery as soon as it would drop to 2 thirds.
other than that it was a pice of cake to use and footage was grate.
    • Meh. I "see" a typo above, that should have been "sell".
    • The clutch pedal has a procedure for adjustment. This can only be done after you are 100% sure the system is absolutely free of air bubbles. You must bleed the clutch master cylinder first, then the "separation pipe" which is the clutch damper line, then the operating cylinder as detailed in the service manual. Also, you must fully depress the clutch pedal between shifts. Just because you can't feel it grabbing does not mean the input shaft is truly decoupled from the crank. At high RPM clutch plates are vibrating and moving around, you need to give it the best possible chance of success. On the BCNR33 Nissan revises these adjustment procedures slightly but not by much: I would be careful with trying to play games with these adjustments. As for the Nismo operating cylinder they say a lot of things. In practice the twin plate clutch needs less movement on the clutch fork to disengage because the whole stackup of the flywheel + friction plates + pressure plate is much taller. Personally if you find that the clutch still disengages too high at the top of the travel I would try the Nismo operating cylinder. Make sure to follow the air bleed procedures.
    • Thank you for the links. I’m going to go with the 6pin plug you used. next step is rust treating re painting dash support bar and steering column then the 6pin cradle plug when it arrives in the mail.
    • I don't how much the car makes a difference or whether it is just a question of gearbox and clutch. On mine it's fine. Pull type Nismo coppermix twin (standard, not competition) on the 5 speed in my Stagea. OEM slave cylinder. Bite point is a few cm off the very bottom of the pedal. Clutch pedal all the way down to put in gear, and when heading off at the lights, there's a tiny bit of nothing and then it starts biting. And fully engaged before the pedal is all the way released. There's a bit of play at the top where the pedal does nothing anymore. Are you in Australia @ck_chino? If you are set on using a Nismo slave cylinder I have one new-in-box at home. Ordered it together with the clutch but didn't get it fitted. We can work something out if you want it
    • I am using a pull nismo coppermix twin in an r34 getrag box, had both the standard slave and  then the nismo one. Adjusted pedal to get bite point how I wanted , it is on the higher side, but would fully disengage past half way down.  I also read that the nismo slave won't work but I had no issues with the stroke, might become one later as clutch wears but 2+ years of happy motoring so far.  Take the above as one input only, specially as my setup is a bit unique in that I am using an S15 clutch master , cefiro clutch pedal, custom braided clutch line. Lots of variables at play.
