took mine out on sunday, cut my hand on various screws and stuff like 6 times.
In my r32, i unscrewed the fuel line bracket just forward of the filter, then got the filter to an easily accessible place, then pulled like a MF, just came off...
try getting pliers, clench just at the end of the nozzle ( on a soft spot in the line) and lever the pliers against the fuel filter... worth a shot... : )
i just changed my fuel filter on the last service its a bitch...
put hose clamps on either side of it so u don't spray fuel everywhere (also makes the car start much sooner after you have changed the filter) then remove the engine side first (pull damn hard (don't yank it from the engine, hold the hose and the filter and pull them appart) then pull really really hard to get it off from the fuel tank side. thats the hardest....*
My advice is to not do up the hose clamps too tightly when you put the new one in, because I reckon this is what makes the hoses harder to get off next time. Just tight enough to not come loose should be enough.
when i did mine i rememberd getting one end off but the other was tight asss....so i just cut it off...haha. im very paranoid so after i put everything back together i went over the hose again with a wet rag to neutralise any petrol that leaked in case it ate into the hose or caught on fire from the engine heat. as i said im paranoid...lol the car was so responsive after that. any idea on how often the filter should be changed??
Guest RedLineGTR
depends how u run your car also...if u run it to empty then alot of the shit in the tank is more likely to get sucked up...if u leave like 1/4 or abit more in the tank before u fill up, dont chnage it too often...but its a simple thing to do, makes sure your engine gets all the fuel it needs and wants.
No one has yet properly explained to me why this is the case. I don't buy into it personally.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List: 1.Anna S 2. Luke S 3. Jesse Givens-Lamb 4. Luca Stamatescu 5. Madeleine Stamatescu
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
