yes, added unsprung weight and rotational inertia will effect your performance of ur suspension, acceleration, and braking.
big? depends on ur definition, id certainly focus on a lot of other things before i spent big $$ of ultra-lightweight wheels, but i would stay away from heavy wheels.
personally i look for a strong rigid wheel which is relatively light, when u buy a heavy wheel they are often not only heavy but weak.
https://www.sau.com.au/forums/topic/252628-heavy-rims/#findComment-4368845
Weight is also relational to size. Stick to a smaller 16 or 17 inch rim. It is possible to find fairly light wheels in these sizes at a decent price.
And as above. Yes. Pretty big impact.
Again, lightweight attractive wheels in a good sieze = $$$$. Best go a smaller rim, thats not heavy but not "light" and spend the money elsewhere to make up for the additional unsprung weight
https://www.sau.com.au/forums/topic/252628-heavy-rims/#findComment-4369014
Hey all,
I've got some to my experience with rims some very heavy ones, the advanti 3 spoke ones. My question is do heavy rims make a big impact on handling performance and straight line speed?
Cheers guys
Handling? Yes.
Straight line speed? No.
The way to understand it is pretty straight forward. You may think the springs in your suspension hold the car up off the ground. But what they actually do is hold (Push if you like) the wheels onto the road. The heavier the wheel is the less capable the suspension will be of maintaining an even amount of force on the road after the wheel hits a bump. That is why (Simplistically anyway) a bad set of wheels can disrupt the handling of a car.
https://www.sau.com.au/forums/topic/252628-heavy-rims/#findComment-4369648
A few years ago i was reading a magazine (Wish I could remember which one now for reference) where they took a stock evo and gave it to a professional driver who posted some very consistent times around a track. Then the put some very expensive lightweight wheels on (same tires) which he then took out for a few laps - the result, only a few 10th's of a second quicker.
Oh, and as for the increase in sidewall issue, take into consideration a formula 1 car tire - massive sidewall...
Edit: Sorry, I re-read my post and thought it sounds a bit arrogant - just trying to back up the idea that they will make a difference, but not a big one, not trying to start an argument :D
Edited by Medium Dave
https://www.sau.com.au/forums/topic/252628-heavy-rims/#findComment-4372152
Edit: Sorry, I re-read my post and thought it sounds a bit arrogant - just trying to back up the idea that they will make a difference, but not a big one, not trying to start an argument :(
lol F1 tyres are a tad different to street tyres mate.
https://www.sau.com.au/forums/topic/252628-heavy-rims/#findComment-4372743
What wheels before and after?
If I remember correctly Evos come stock with either Enkeis or BBS rims. Both of which tend to be reasonably light and strong already. So going "lighter", unless you managed to score magnesium or carbon fibre rims, isn't going to be as big a gain as with the same-as-a-Maxima cast wheels (or pig iron Tempe Tyres nuggets).
Any single mod that can pull a few tenths is still a good gain. In a car that's already reasonably well designed, you'll only find a little time per mod.
As an aside there's more to wheel performance than just weight. Rigidity can make as much of a difference. Have a read of this.
https://www.sau.com.au/forums/topic/252628-heavy-rims/#findComment-4373243
Ok, cant say much about handling because it was on the street so dont throw it around....but acceleration in my car was far worse when i had my 18" cast Lenso wheels (13kg each) on compared to my 17" forged Weds (6.7kgs each)
The difference in acceleration was dramatic, the 18" Lensos lasted about 3 months and then i sold them as even for street rims i didnt like how doughy my already compromised car felt
https://www.sau.com.au/forums/topic/252628-heavy-rims/#findComment-4373270
i would have to agree with all of the above ... light weight rims do make a difference..
im running p1 buddy club racing rims.. which are about 6.XX kg per rim. 17 inch tho...
i think it would be best if u look @ these kind of rims if your more on the performance side then the cosmetic side.
i feel that there is no need to go above 17inch rims for performance side of thing...
17 inch rims still can fit nice brakes behind them...
https://www.sau.com.au/forums/topic/252628-heavy-rims/#findComment-4373688
Volk GTP's 17x9.5 on my gtr are lighter compared to the stock 16x7 r33 gtst rims with stock tyres. The GTP's are among the lightest of the forged rims.
not really, they are very light (ive had a set myself), but not amongst the lightest.
https://www.sau.com.au/forums/topic/252628-heavy-rims/#findComment-4389217
    • H2 (for cars) will never happen. It's not reasonable for any number of reasons. It's also not reasonable for almost all of the industrial uses that the fanbois say that it will be used for, again for a large number of reasons. There are some cases where it will be good. But, even those will be massively hampered by the economics. The only way that H2 can be economic is if we somehow manage to get from where we are to the other side of the economic-valley-of-death in which no-one can operate. You need there to be sufficient renewable generated electricity to be available so that it is effectively free. Once you are there, you can do whatever the hell you want and hang the efficiency. But until you get there, the ever diminishing value of electricity makes it harder and harder to encourage businesses to build the new generation capacity, and they will simply stop investing in generation projects. (I kinda think there needs to be just government money spent on building the required capacity in a non-commercial way, similar to how the first fossil fueled grids were built, as national-government owned utilities. And probably some nuclear in there to start. But this all should have started 10-15 years ago to avoid the chasm of death that we face right now). Synth fuels will be much more likely, but will only occur is there is at least some renewable H2 production, because you need H2 to do it. And you need stacks of free (or at least extraordinarily cheap) energy because assembling molecules back into fuels is exactly the opposite process to burning the fuel, and the reason we burn fuels is because there is so much energy squeezed into each molecule. So you're somewhat subject to the same economic valley of death problem as above anyway. That is unless people are willing to pay the current equivalent of $5 or $6 per litre of petrol-ish liquid fuels. Can you imagine it? The squealing at $2 now is bad enough.
    • This is so cool. Get a dashcam that records audio and hopefully you'll catch it.  Maybe there's a brand or some kind of markings on the back ? Are the pics hand drawn? I love it so much.
    • Hahaha yep, point(s) taken. I just like seeing different things and an EV in an R32 is pretty different. I'm not on the EV band wagon, I'm waiting for synthetic fuels or hydrogen personally.
    • I mean it's probably likely that people overestimate their skills in dialling in a setup and noticing the changes. I had SK shocks and springs, and added heavier springs and got them revalved by Sydney Shocks to suit based upon what I told them I wanted the car to handle like. I got back a completely different feeling set of shocks, which probably (?) feel great on track but holy hell are they rough on tram tracks and the like. The shock dyno actually looks pretty similar to Shockworks (from what I can surmise from a screenshot of a youtube video - and my dyno printout...) Truth be told I doubt I'd be any faster or slower with either setup, or camber/castor combination. I also had whiteline eccentric castor bushes up front of my R34. I removed them and put in poly non-adjustable ones to soothe my OCD (nobody ever set the castor the same side to side, and it'd be near impossible to do) and be happy the wheel is centered in the well now for clearance reasons. Yes I wanted it to move 1mm 'back' :p I've effectively set my castor back to stock, negating all the benefits of that which is supposedly massive. I've probably also altered toe and camber in a negative (detrimental) way. I can't tell any difference steering the car.
