you do not solder the "filaments to the probe" as you put it....the dry joints you solder are located under the square cover.
Sorry, I had a quick look at it DIY.
hey guys
just wondering what kinda power the standard rb26 injectors and airflow metres will handle im looking for 400rwhp i currently have hks gtss and a forged engine.
can i use rb25 afms if so what needs to be done to get them to work on the 26
and what cc injectors would i need?
cheers
Found my stock afm's ran out of res at about 410rwhp- green plug RB25(series 1)/RB20 plug straight up, but are bigger in size. You'll have to do some small fabrication to fit the rear one (45 degree bend in 3'' is what I used) and you can squeeze the stock rubber inlet tube over the larger afm for the front turbo . And you need a retune, power FC has these afm's in the options menu somewhere.
    • I would again like too thank Matt for his help in me sourcing the detachable hard top for the little red car, without Matt's assistance in inspecting it and locking it down, I can guarantee it would have sold before I could get up to see it,  and as that was the only available NC hardtop in Australia, I consider myself extremely lucky on multiple levels To say I'm more that happy would be an understatement And, it is 100% water tight, I drove through torrential rain coming back south, and by torrential, they type of rain that doing 40kph in a 110kph zone was a real thing, and even then, the standing water on the Hwy was deep enough to throw waves I'm also more than happy that the huge "BEASTS" that Matt calls dogs didn't eat me for lunch, I'm sure the sniffs and licks were more to "taste test" me, over being to friendly Now to work out what colour to get it painted, panel match, or gloss black........first world problems are real
    • Actually I might have figured out. Looks like there is a tab according to google images but it's hidden. Silly me.
    • No clips on this one like the other connector. Only that red tab that I can push slightly up.
    • For any loom connector that has an obvious release that resists pushing far enough to unclip, just spray some silicone lube into it. You might also benefit from using a bent screwdriver or small pick to push in the right place at the right angle.
    • Hey all, I went to try and fix my indicator not canceling, but I couldn't remove the clockspring cable under the column so I could twist that green thin. Anyone know how to remove this cable? I see this red tab but didn't have any luck. I was thinking of unscrewing it but wasn't sure if it would cause issues. I did notice for my indicator stalk, 2 out of 3 cables were plugged in but the last cable wouldn't fit in the stalk. I'm getting it's for fog lights. It was like this when I originally pulled it off.
