I am about to re-ground my car's negative terminal on the battery, and wondering what others have done, and where they have grounded to....
Car: 1992 Nissan R32 GTR Skyline
Battery: Optima Yellow Top
The Plan: To use an alloy battery clamp and zero gauge oxygen free cable.
I plan on grounding to the current chassis ground (cleaned and re-prep'd), but also want to ground to the engine block.
Thoughts from others that have done this?
Cheers in advance.
B.
https://www.sau.com.au/forums/topic/252669-re-grounding-battery/
two cables unless you can get the correct termination from a autoelect supplier. also 0 AWG welding lead - same stuff and a bit cheaper. forget bling when its really fucntion that counts.
Cant go cheaper than free Chris, I have a few 2 meter lengths floating around at the moment, so I was planning on making use of them (not for bling, but for the actual desire to have a strong ground, R32's are not very good, considering they have an 8-gauge for grounding).
So what are the best ways to hook this stuff up, and why 2 leads?
B.
two leads for the reason you have a T piece in the middle of the ground wire and a lug on end of it. to do it properly you would need a matching battery terminal, T tap terminal and a lug onthe end. in two pieces battery terminal, lug 2nd wire with a lug on each end.
