I consulted my Japanese GT-R book and from what I can gather, there are no definitive answers, only because it was offered as a normal model, like a V-Spec II.
I can tell you there were 3 M-Specs built as test models in January '01 (BNR-400801-803), before they were officially released in April '01 (BNR-401356 onwards). The EY0 gold paint came the Japanese Primera.
https://www.sau.com.au/forums/topic/252671-r34-gtr-m-spec/#findComment-4369798
interseting.. so when they quote the number of v-spec II's this must include the m-specs.
someone once told me that they were produced for 6 months with little made each month due to the time consuming hand stitching for the leather interior.
it would be nice to know the actual number though!!
https://www.sau.com.au/forums/topic/252671-r34-gtr-m-spec/#findComment-4371047
There probably weren't many - I know they were only built at a rate of around 50 per month, because the leather interior was very time consuming to make and they also had extra staff on hand for quality control.
Working on your six month production run, you'd be looking at not much more than 300 cars. PM me your chassis number and I'll check it in FAST, but I'm pretty sure the M Specs come up as V-Spec 2s in there.
Edited by Iron Chef
https://www.sau.com.au/forums/topic/252671-r34-gtr-m-spec/#findComment-4374608
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
    • You would need to paint your hardtop again though
    • I have an old R32 in the shed that hasnt moved much in the last few years and probably should see the light of day. At one point I had a Nismo 1.5 centre put in the rear diff. It is a clunky nightmare POS of a thing on a good day. To make it less painful the initial torque setting has been put on the minimum (7.0kgf-m, mid is 9.5, high is 14) and the oil changed out to something more slippery. But it is still awful and ruins the vibe of the thing. So my questions are: Given I have the original parts sitting in a box somewhere would it be better to rebuild the thing again, reverting to more purity? Is there a standard kit or do you just go and replace the friction plates etc and shim it the way you like it. How much initial torque does the standard R32 rear diff have? Or does the Nismo disc kit offer a better solution - the caveat being the initial torque for both options appears to be higher than the clunky 1.5 way. There appear to be two Nismo disc kits: 3843S-RS520 for 8kgf-m. 3843S-RS521 for 12kgf-m. Or is the easiest solution to reshim the Nismo diff to make it looser?
