Hey all,
Currently halfway through doing a 100,000k service on my r33 gtst and in my kit from kudos was cam seals. Now i can only assume that these are seals that would be behind the cam gears but situated between the rocker cover and the head? If so i would think thats kind of an epic thing to do but anyway some help on that matter would be great as i can find zero information about people who have actually fitted these seals when i search.
My next query is realted to the intake cam gear. obviously there must be some moving parts to make its vvt side work but should the centre be filled with oil? started taking the little centre cover off to see how hard it was to remove the gear and oil started to leak out.
Any help would be much appreciated :D
Cheers
Camden
https://www.sau.com.au/forums/topic/252693-cam-seals-intake-cam-gear-rb25/
Thanks for the replies :( Think i might leave the cam seals for now as i have no leaks.
Just out of curiosity can anyone explain how exactly this gear achieves its vvt. I'm assuming its just a set physical change somehow..maybe at a certain rpm but nothing electronically triggered?
Cheers
Camden
Cheers
Camden
I'm not 100% but I beleive this is how it works:
At a given RPM the ecu commands the VTC solenoid open (electrical) allowing oil pressure to the cam gear and advancing the cam. The ECU commands the solenoid close at a higher rpm to cut off oil pressure and the gear returns to its original position with the aid of the spring.
Edited by maximajim
    • But it's much better to use a freedom unit that has four different possible meanings...
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
