http://carsales.com.au/used-cars/private/N...r35&trecs=5
a lot of mods for the money, (which I still doubt he will get)!
edit: if he is a member here, I'm sorry, I take that back. Great price! GL with the sale!!
still it is interesting what passes "compliance" these days.
Edited by r34nur
https://www.sau.com.au/forums/topic/252700-535kw/
he already has 1 R35, and he was talking about another... I'm assuming that one has landed as well... dunno really
The R35 is registered too, he gave us the option of having the V or the R at the show and I said we will happily take the V :P
I figured every man and his dog would have an R at their stand at final battle... there wasn't even one
https://www.sau.com.au/forums/topic/252700-535kw/#findComment-4370172
Yep, Carl's car is gorgeous!
As for getting through compliance, my understanding is that the car came over stock, and he had it twin turbo'd. It then let go on him at Wakefield, after which he had the engine shipped to teh US for the works, which is what you see on it now.
Nothing better than a Skyline fan who has the money to enjoy what he loves.
https://www.sau.com.au/forums/topic/252700-535kw/#findComment-4371923
Yeah. Carl's car has been on sale for a while. It's a well turned-out car, and his R35 is sweet. ActionDan got a drive of it soon after Carl got it.
Carl has already expressed interest in doing an engine swap (with cash adjustment, obviously) to someone who wants that powerplant in their car.
https://www.sau.com.au/forums/topic/252700-535kw/#findComment-4373235
    • OK, well, in that case, the suspension specialist is either a moron, or you aren't understanding what he was trying to tell you. Nismo arms are not really different than stock arms. Both are fixed geometry. I don't know if the Nismo ones are a little shorter than the stockers (or perhaps even a little longer) or the same length, but....if you swap from stock to Nismo, whatever happens to one side will happen to the other side. It will not cause it to steer left or right. That is unless you have adjustable bushes in your stockers, and they happen to be adjusted to dial out some bent chassis shenanigans. But, if that were the case, you'd just put adjustables in the Nismo arms anyway, because Nismo arms are essentially just expensive stock arms. And doing a wheel alignment is just a weekly thing in my world. I have had the suspension apart so many times this year that I've lost count and just about worn out a torque wrench. I'm out in the shed right now cutting up some alloy section and making bases for my new stringline setup. Got to make new swivel plates next, then I'm good to do toe properly, as well as camber and bump steer.
    • Yeah, nah. Not a thing. The gasket between the top of the plenum and the runners is far more likely to blow out when it gets old, and not really at ~14 psi. These things have been run to double that for 30 years without that being a common thing.
    • I plan to pull the intake manifold off and check the gaskets, i read that the block to manifold gasket can blow over 14psi and when i picked up the car it was set to 1.2bar on the controller. Send the injectors out for cleaning. Ill also pull the cam covers off and do an inspection, check some valve lash. Someone also said that the timing belt can rub or vibrate against the belt cover and make that sound. Definitely need to get an AFR gauge on it, if it was lean idling im sure it wont be happy
    • Well, it is an unusual noise. Use a 2 foot long bit of garden hose stuck in your ear as a stethoscope to pin it down to a definite location. We'll never work it out across the internet.
