Im running splitfires with BCPR6ES-11 . Works fine not missing or anything. I've also noticed when i use to run BCPR6ES-0.8 it use to run more rich and i could hear my exhaust pop and stuff... un-tuned as well. I will be geting my tune soon
My current mods are:
Full Turbo Back Exhaust system 3inch
FMIC
POD
Walbro Fuel Pump
Hypergear highflow r33 turbo
5 Puk Button Clutch
Power FC (Not installed yet)
Z32 AFM(Not installed yet)
Im running Splitfire coils and a HKS TwinSpark CDI system. @ 18psi of boost i can run 1 - 1.11mm gap with no missfire.. at 25psi of boost i get a bad missfire that goes away when i go down to 0.9. I havent done back to back tests of the HP difference but its going to be pretty small. For peace of mind, and because its a track car, im just going to stick to buying 0.8mm gapped plugs. there is possibly 10hp per 0.1mm increase in gap size but if you have a missfire your going to lose all of those gains and then some.
@ 10psi with splitfire you will have no dramas at 1.1. When you start running higher boost numbers you need to lower the gap or upgrade your ignition system.
i know the R in the part number means resistor type and non resistor type and i think your supposed to use non resistor in 25s, anyone know if it makes any difference? i have resistor type atm, simply because supershit didnt have anything else.
I was running 1.1 on standard colis with a high flow @ 12-13psi, never had a problem till i messed around with the avcr and accidentally hit 18 psi then it started to break down, bought .8 plugs and have not gone back.
Any one tried the spark plugs in the pics below?
Hi thought I would put in my 2 cents worth. This is my experiance and what I was told. A colder plug has a colder spark and producers less power, however it is more conductive and therefore will ignite under more pressure. A hotter plug has a hotter spark, producers more power but is less conductive, therefore wont ignite under higher pressure. A bigger gap provides a bigger spark, which ignites the fuel better and producess more power. However a bigger gap is less likely to ignite under a higher pressure. For example, someone befor said that they put in a spark plug that was running realy smooth at idle and in the lower rev range, but was missing up high. I would say that they have a spark plug that is too hot. Ignite the spark really well with less pressure and will run better than the other plug but wont ignite as well under pressure. Therefore misses up high. Thats why alot of people with close the gap to make it easyer for the spark to ignite. I run an 8 in heat range with a 1.1 gap. When I put in a 7 with a gap of 1.1 I get better fuel economy (almost an extra 100km to the tank) and more response down low. But when I put my foot down and boost gets over 12psi it will start to miss. So the trick is to get the right heat range with the right gap for each plug. I use NGK plug and I use the V-groove. I also use the copper plugs too, I tried the iridium plug but couldn't get them to work for me. I even sent my plugs to melbourne for one of there enginers to tell me what to run, but I went back to what my tuning shop told me to run.
Now I am not saying that I am right, this is just what I was told, and I thought I would add it as I thought it might give people enough of an idea on how to experiment with ther plugs and there gap and there heat range. Anyway hope this helps someone out there.
i guess with 1.1 it will help out with fuel and have a better spark to burn it all , car seems to run fine and will test to see how the fuel usage will be in few weeks,
i thought that it would not run 1.1 gap as others have mentioned but clearly few people run 1.1 and its fine with upgraded coils or stock ones that are in good condition.
geraus were you member on mx6.com :D i seen your nickname there
With a little over 300rwkw mine has no issues with fuel economy.
11L/100km.
Injectors are clean, zero vac leaks, new o2 sensor, new afm, std air box with 100mm cai in to the bumper and a good tune.
It hasn't always been that way.. Fuel economy dropped to 14-15L/100km when the injectors clagged up and were dirty. Replace injectors and o2 sensor rough injector trim in the pfc as the injectors were larger and economy went to 12l/100, tune with new afm and 11l/100 driving to and from work in light traffic.
My 300+ thousand km coils were arcing all over the place and breaking down with anything more than 10-11psi.
Ripped out the old grey sensor safe silicon coated them all up (inbetween the bracket and every little cranny), up to 24psi and no break down. Spark plugs are gapped to 0.8. The tune had them gapped to 0.6 for good measure but I've since pulled them and regapped out of curiosity but all is good.
Edited by TheRogue
well mr rogue thats some impressive economy results! who tuned your car? and what engine managment are you using?
Its probably more to do with a controlled right foot than anything else.
I can get over 550-600km's to a tank on the FWY, and 400-450km's to a tank around town and im @ 280rwkw at the moment.
And there are two things which are hurting my economy...
1. AFM reading thats all over the place at any given moment (due to loom issue)
2. Diff gearing... 100km/h im almost on 3000rpm
So i dont think its uncommon... the urge to hit boost is just strong in some people :P
So i dont think its uncommon... the urge to hit boost is just strong in some people :down:
So i dont think its uncommon... the urge to hit boost is just strong in some people ;)
For some its not just an urge, its an addiction :P
I have not done a freeway run since my car has been retuned but now im making 210rwkw and with the retune i get around 15ltrs\100k's around town with a fair bit of spirited driving, before the tune i could only get that figure if i mostly babied it.
Exactly it...
Right foot and a car that is in good nick as well as tuned nicely.
I change gear at 2000-2500rpm with larger throttle openings. The car runs 15:1 afr's until it starts to make boost so even at those larger throttle openings its still running leaner afr's.
I found the std PFC tune to drop the afrs in to the 12-13's as soon as the throttle was cracked open any decent amount once its out of the o2 trim capabilities.
2-2.5k it has zero issues accelerating at the traffics normal pace. Keep revs low. Don't hold gears out with super light throttle as higher rpm and less throttle input = increased pumping losses and lowered DCR (dynamic comp ratio) so decreased effiency and torque as a result.
Revs low and more throttle with a tune to suit.
Edited by TheRogue
    • Hey @Butters, did you end up getting this clutch in ? I have just ordered to a uniclutch track to go in my getrag 6 speed that’s in my BNR 32
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
