This is a private sale and is not a business!!!
Make/Model:
Nissan Infiniti Q45
Year:
1990
Kilometers:
128000
Car Specification:
1990 Q45 Infiniti 4.5L Quadcam V8 Semi-Forged Internals
Leather Interior
Active Ride Height Suspension
Nissan Patrol Auto Gearbox with hardened planetary gears
17 inch wheels
VIP Tinted Windows
Custom VIP Body Kit
Kevlar bands
Heavy duty seals
Custom valve body
Custom 3g stall
Remote oil cooler
Sunroof
Electric seats
Asking Price:
$7000 for both cars, or swaps for something of interest show me what you have open to offers
Brisbane
Contact Details:
Just send us a private message and I will get back to you asap!
Other Comments:
Really Sweet car to drive.
Pictures (Click the pictures for larger view)
Make/Model:
Mitsubish Scorpian GL
Year:
1983
Kilometers:
85,000
Car Specification and Mods:
2.6L 4 Cylinder Engine (JAP IMPORT) not the Australian made engines which are crap
5 Speed Manual
Holley Carburetter (180 dual throat, mechanical secondary)
Exhaust (2 inch after factory manifold)
Larger Sigma front anti roll bar
Manual gearbox out of GE Sigma 1850cc
Lightened standard flywheel
Modified tailshaft (to suit gearbox)
Welded center in differential
Firmer (and cut) springs
The tops of the struts have been turned 180 degrees to give slight negative camber
Harder four wheel drive compound front brake pads (Bendix)
Bonnet is shaved and held down by four metal pin-like supports on top of the bonnet
Has a battery disconnect turn-key complies with CAMs rules.
Brisbane
Contact Details:
Private Message
Other Comments:
This car is really fun to drive, love kicking the rear end out the side its fantastic. Engine is in top notch condition, the car has been so well looked afterl when I bought it, haven't used it so its still in good condition engine is kicked over and run every 2 weeks.
Comes with semi-slicks and some other spare parts.
I do have another seat for the front left with rails however the rails need a slight modification to be mounted which won't be hard or cost much you just need a welder and 5-8mm thick steel plate and drill some holes weld up to the existing rails and wella you have a properly mounted front-left seat.
Do not have the rear interior.
Also comes with fire extinguisher.
Edited by airflow
Price drop $6000 for both
I have a real nice C33 Laurel that i would swap.Its RB20de auto,has been stored in a workshop for 6 years.The only thing it needs for a RWC is a screen witch i have on back order.
If your interested call me on 0413729446
cheers Jeff
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to come I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
