As stated make sure you have a Arial Amplifier has power if its the factory headunit.. if its after market remove the arial amplifier and go directly into the headunit with the two pin to single pin adaptor.. I had shocking reception in my car so i removed the arial amplier and went directly into the headunit with just the adapter and now have 100% reception..
Edited by SHIZNT
ah i see, thanks peoples, any chance of a pic of those aerial wires that i'm supposed to hook up to?
cheers big ears
p.s. yeh i do have aftermarket headunit, that i installed, so i'll take it out on the weekend for a look-see
Could even be like my RS4S and have two strips that run up either side of the front window as the aerial. I have traced the wires back and it is deffinitely for my aerial, goes to a 2 pin plug into an adapter for aftermarket headunit.
