Hi! i purchased my R34 skyline 25GT Auto for like a month now, and its hit 95,000kms.
Thought its time to do my 100,000kms Major Service
I live in Keilor, Melbourne. ( ON THE WEST SIDE )
Anyone know any good places that does good service and are trustworthy?
Is this list a good list of what to do for my major service?
Timing Belt Kit
  • 1 x Genuine Nissan Oil Filter
  • 1 x Genuine Nissan Timing Belt
  • 1 x Genuine Nissan Water Pump
  • 1 x Genuine Nissan Thermostat
  • 2 x Genuine Nissan Cam Seal
  • 1 x Genuine Nissan Crank Seal
  • 1 x Genuine Nissan Tensioner Bearing Spring
  • 1 x NSK/NTN Timing Belt Idler Bearing
  • 1 x NSK/NTN Timing Belt Tensioner Bearing
AUX Belts Kit
  • Water Pump/Alternator
  • Power Steering
  • Air-conditioning
Spark Plugs
  • 6x NGK Platinum, PFR6G
OILS/FILTERS
  • Engine Oil
  • Oil filter
  • Fuel filter
  • Gearbox oil
  • Diff Oil ( Not sure if needed! Don't know what it is) ;)
  • Transfer Case Oil ( Not sure if needed! Don't know what it is) :action-smiley-069:
  • Radiator Flush
Is that all good for a major service? the reason i'm doing all this is because the previous owner didn't have any history for services, therefore i want it all done for peace of mind.
i don't know how much this will all cost but the timing belt, aux belts and spark plugs already cost me around $700-$800
O.H Performance in Sunshine North charges $400 labour for anything worked in the engine, is that a good labour price?
Also is Kudos Motorsport parts a good price? or are there places cheaper? also are they trustworthy?
I'm a newbie to all this so please don't tease me :D i'm trying my best to learn stuff.
Any feedback will be appreciated!!!
Thanks for your time.
Edited by Aznbongsta
RE Customs in Sprinvale.
16 Yiannis Court
Springvale 3171
Victoria, Australia
Tel: 61 (03) 9548 3414
I'm in the west but still make the trip there to have all of my work done. ;)
Hi! i heard RE CUSTOMS are good but so far....
do they let you stay around and watch them? because how do i get home or go somewhere else without the car?
ALSO anyone heard of MAKSPEED located near Highpoint? are they any good? they been around for a while i heard.
I don't know if you'd be getting a 100k service done in a day...best bet is to call and discuss it with them...
ic ic...
Well anyone of you skyline fellows think my list of parts/stuff are good for my 100,000kms service?
i only been sourcing around and just gathered up a list. i'm not 100% certain if they are the parts/stuff i need for my major service.
ic ic...
Looks pretty good to me...Only I wouldn't waste my money on fancy spark plugs...Coppers will do just fine and will set you back about $20 for 6
THanks Dezz, you been a big help....
ive been down to C&D motorworks and they said they charge around $70 a hour for work....BUT how will i know how many hours he spent? they can just make it up right?
ill give Chasers Motorworks a try too, heard they do good jobs.
Any other information will be very thankful.
Sorry if i'm annoying some people out there, just that i'm a student that works hard for his money and don't want to get ripped off by a mechanic since i don't know much about cars.
100k services generally aren't cheap, as you'd know having already spent $700+ on parts alone...Having said that, all you'll really need now is the labour, so it shouldn't really cost too much...Only thing that might add up is the labour on changing the timing belt.
Best bet is to choose a workshop and get a quote for the specific work to be done...Once you've got a quote you'll know roughly what to expect, and the final bill should be around the quoted price, unless something unexpected comes up.
Yea, i guess your right. Well i havent bought the parts yet, i don't want to transfer like $800 to some online store. Maybe if i pay by credit card it will be safer.
Dezz!!! have you bought parts from Kudos Motorsports? or has anyone?
Yes I Have. Andrew is trustworthy, and you shouldn't have any problems.
Here's his feedback thread - http://www.skylinesaustralia.com/forums/Cu...ck-t103442.html
Might be worth contacting him before you transfer anything just to double check what he has in stock etc...
i hear alot of good things about RE customs and i was going ot take my car there but it was to far away.
im not saying dont go to RE customs im just suggesting another good place to maybe consider as they are closer.
they are EAS performance located in airport west tullamarine ph:93302001 . ive taken my car there a few times and they are fantastic, my mate takes his car there too. and so does AL, which is a member hear, he was the one that told me about them when i was looking for a place.
so thats just another place for you to think about.
RE Customs as what everyone has said.
Or if its close for you and not needing to drive all the way out to Springvale I go to Le Mans Automotive in Templestowe and speak to Shane.
Factory 1 / 15 Websters Rd
Templestowe
VIC, 3106
Australia
(03) 9846 2761
He did all the work on my diff, turbos, gearbox, general maintanace and service.
He is trustworthy and knows what he is doing.
If your car is all stock - the nissan dealership can help (however I'm not sure if all of them do imports). I remember them quoting around $300 for the timing belt change alone.
With all the stuff you want done your car will be in the shop for 2 days maybe even longer if the workshop is busy. (regardles of the place you send it).
I personally find if you get the mechanic to do too much work they tend to cut corners.
Here are my tips to.
Timing Belt Kit
* 1 x Genuine Nissan Oil Filter - Change
* 1 x Genuine Nissan Timing Belt - Change
* 1 x Genuine Nissan Water Pump - I'd hold this off
* 1 x Genuine Nissan Thermostat - Change
* 2 x Genuine Nissan Cam Seal - If its not leaking - hold off
* 1 x Genuine Nissan Crank Seal - If its not leaking - hold off
* 1 x Genuine Nissan Tensioner Bearing Spring - Change
* 1 x NSK/NTN Timing Belt Idler Bearing - Change
* 1 x NSK/NTN Timing Belt Tensioner Bearing - Change
AUX Belts Kit
* Water Pump/Alternator - Change
* Power Steering - Change
* Air-conditioning - Change
Spark Plugs
* 6x NGK Platinum, PFR6G - Change
+ change you coilpacks with splitfires as the stock coils tend to start giving issues after 100k
OILS/FILTERS
* Engine Oil - change - recommend Castrol GTX3 for 2 months to flush the engine then change over to a more premium oil of your choice.
* Oil filter - change
* Fuel filter - hold off
* Gearbox oil - hold off - Castrol Transmax Z seems to be the choice for most people.
* Diff Oil ( Not sure if needed! Don't know what it is) blush.gif - hold off
- Only if your car is an AWD you will need this changed
* Radiator Flush - Highly recommended (recommend Castrol radicool) + change your hoses too.
Templestowe
VIC, 3106
Australia
(03) 9846 2761
Thanks Man, will get some quotes from him too.
THANKS THANKS
Timing Belt Kit
AUX Belts Kit
Spark Plugs
OILS/FILTERS
WOW! iseekool thanks alot, thats really helpful. maybe ill buy those oils to and provide them to whoever i take the car too.
CHEERS THAT'S GREAT INFO.
Also i forgot to mention, when i change gears in my auto the car seems to move or shake forward or backwards a little.
IS DAT A SIGN OF MY GEARBOX SCREWING UP? or just needs new oil? My uncle mentioned something about getting my gearbox flushed and add new oil... is that suppose to make it better?
Thanks mate, will check it out too.
i got told from RE customs for my stagea (same engine) around $1400 parts and labour., thats including oil's and the stuff you listed.
but yeah give atleast 2days,
with a normal service normally one guy can get it done in a couple of hours , but major service, wouldnt hang around for it unless you have a tent.
i've already started buying my stuff for it
1 x Timing Belt
2 x Cam Seal
1 x Crank Seal
1 x Tensioner Bearing Spring
1 x Timing Belt Idler Bearing
1 x Timing Belt Tensioner Bearing
got the kit off justjap.com
P.S Westal station is just down the road, can train it back home ... ?
Went to Jap Warehouse also known as DGEN at tullamarine today.
David seem like a good guy, the parts above i wanted done came around to $1370 exclude the water pump, thermostat, tensioner bearing spring.
Price is as follows:
Major Service $280
Cam Belt $650
Cam Seal $120
Gearbox Service $80
Diff Oil $60
Radiator Flush $60
Aux Belts $120
but the timing belt is now GATES........
he said its a performance type, is GATES timing belt any good?
And what about pricing? any good?
I still have to check out EAS, Chasers and maybe RE Customs if i have time.
    • That's the thing. Especially at idle, changing the cam angle by that much could be spewing more fuel out the exhaust courtesy of everything happening that bit later. More fuel also means more air (if the fuel didn't burn, then neither did the O2) and so the O2 sensors can start to tell interesting but misleading stories. And the specifics of what is happening could easily be affected by everything else you changed as well. And it could be dynamic, where a few revs more or less could somewhat change how the engine is breathing.
    • Good idea on the temp probe. The mv readings of the O2 sensors are very similar to one another, as is the injector pw. I went through logs in the past to see if there was a discrepancy and there is. Because they alternate up and down as narrowbands do.. they do often 'switch' as to which one is more. They were never 20%+ (more like 1-2%) so it's possible the difference between 20 and 15-17% is a similar discrepancy to 2.0% and 1.7% which I wouldn't have really noticed in the past. We did think about spacing the strut brace. Unfortunately the ~20mm that the GTR brace is lower than the GTT brace is effectively what you need to clear the vents. Moving it up would make it very uncomfortable, but it's plausible that 10mm is a unhappy medium between both hard places... The good news is.. using MR HAMMER it was actually pretty easy to bend back the bent bits to make sure the guard and headlight/new headlight tabs line up right. Yes, we used a R34 GTR guard to make sure the bolt holes all lined up with a known straight guard. As above, you can see the side skirt and the GTR guard are not meant to play together, but everyone seems to think this is a simple fix to the point where nobody who has had these talk to one another mentions how... ...so I'll just assume they know how to fix it when it comes to paint jail time again. Whoever they are. Nobody returns my calls. There's so much changed with regard to the ECU and the car.. that the next step really is to connect the scanner and attempt to drive the thing. It'll be pretty clear pretty fast how in or out everything actually is...
    • That's nasty! I think there is perhaps an inherent problem is using elastomers in such environments. The whole thing can and will get quite hot, and elastomers are not famous for their temperature resistance. On top of that, if the components are cast rubber or urethane and so on, there might be QA/QC problems with bubbles or voids in the material that could critically change their performance. They might just tear apart after being squished (presuming that any elastomers are used in compression rather than tension, I'm thinking that you squeeze one with a void in it and it tears the wall of the void to the outer edge of block, then the next time it extends or otherwise twists, it just gives up). This is all purely hypothetical, but it makes me wonder if the things that they have put into it to make it nice to use/live with are perhaps going to cause occasional failures like this. I wouldn't be getting up in arms over it, unless there are many repeats. I have personally ruined an Xtreme clutch - just an HD thing. I can't remember if it was still behind the 20 or was after the 25 went in. But it inverted some of the retaining spring/clip things around the outside. No-one could explain it. It wasn't thrashed, there wasn't heaps of torque being put through it, and there were no obvious problems other than the above. They were quite concerned by the event so they replaced it even though it was a few years old, which was very nice of them. As far as I am concerned, these things happen with clutches.
    • Any damage to the box/input shaft?
    • Hey there Mate , I just got my local guy to install it Waterhouse Performance, Penrith (specialise Nissan/Datsun and other performance cars) , you can do it yourself if you like , AMS has instructions on their website.  Cheers Pac
