im cleaning out to move to WA i brought 4 r33 wrecks to make 1 good years ago when they where worth alot more then they are now never made a good so i got shit loads of stuff sitting around collecting dusty and taking up room
here as a list of stuff i can remember thats is there
r33 gtst s2 stuff :(
r33 s2 complet interior everything including air bags, keys, locks the lot
silver boot and spoiler paint bit chipped $100
full set of breaks $400
black spoiler with led $100
r33 gtst s1 stuff :)
rolling shell no front panels, head lights or bar for race or drift car with breaks and diff centre $1400
rb25det motor had head work done to4e turbo ecu & loom $1800
5 speed box $1400
or motor box and car to make a good drift car $4200 just to see it gone and put to use
rear seats x2 $20 each
dash pad with all vents $50
cluster surround $50
rear garnish between tail lights x2 $40 each
wiper motor front and rear $20
drivers side door in white paint bit chipping $60
boot carpets and surrounds
lhs tail light in wine red $50
stock wheels
space savers x5
door handles
wiper bottles
over flow bottles
egine loom $200
car wiring loom
sliver roof cut for a roof repair $200
blown stock turbo good for hi flow $50
Stock turbo maniflod $80
wine red rear cut good for one some in need of rear end repair $300
stock inlet manifold complete $100
rear cradle
also have
R34 bonnet in a purple color $300
GTR Stock dump pipes $60
Uras body kit new in box $550
Thats only what i can think of so pm me with some thing u need i may have it
make me a offer on price or the lot i need it gone
pick up bendigo vic :laugh:
pm or call 0424897340
Edited by mattsr31
  • Replies 43
do you have a steering column surround? If so can you please post a couple of pics of the top and the side of it? If in good nick I would buy
will get pics monday mate
Got a gear stick surround?
not sure mate should have let u no monday
Hi, do you have the drivers side window switch surround? also if you have another steering collumn surround i am also interested in one of those.
Thanks
Will
Thanks
Will
no window switchs mate sorry surround i will look 2moro and get back to u
has the shell been damaged or repaired
is it written off or just no approval?
cheers
no damage mate just no approval
    • Hi everyone, I'm generally new to DIY projects, and I've browsed this forum and watched a lot of youtube videos but still have a few questions   Firstly, how does spray painting interior hold up? in particular like vinyl parts, my current mode of thinking is to use methyl spirits to take off original paint, clean/prep well, light coats, no primer or clear coat    Secondly, what is recommended for the headliner and, for example (my car is a r34), the A-pillars which are some kind of other fabric material, do you think I would be successful at retrimming these? or would it be better to go down the blacking out via Dupli-Color Vinyl & Fabric Paint    Any other advice / tips / tricks for refreshing/modernising these interiors?    Thanks
    • As title says  Pm a photo with what u have  Type m style would be good As Hidding a thick front mount
    • Just note that when trying to find a short in a globe power supply, it is best to disconnect the globe as it will allow current through to earth. With it unplugged it is easier not to get confused. Also with the r32 wiring, the high beam has 2 power supplies (one when you push the switch forward and the other when you temporarily pull it back; so if it is the high beam blowing you will need to trace both circuits
    • $75 Location: Gold Coast  Can post via Australia post
    • That's a short. Find the short. It will be somewhere between that fuse and the headlight. Start by removing the plugs from the back of the headlight and dimmer switches, and measure resistance to earth. Supply side (power from the fuse) should have none. The other side should have resistance compatible with whatever globe(s) is there (which is relatively easy to say for a normal globe, perhaps not as easy to say for LEDs). Anyway, if you have very low resistance, you defo have a short. Then you just have to run the wiring like you're running the bowel of a dog (on the operating table) that has swallowed something it wasn't supposed to.
