  • Replies 43
Still heaps of stuff left all must go in 9 days
Hi champ,
Im looking for a few parts:
Interior door handle surrounds - both sides
passenger side window switch surround
drivers knee panel
steering column surround (in case you found it)
My number is 0414 509 399
