Hey all,
Just of last night I have been having some problems with my car. First of all the idle has become really really rough. The car will literally "shake". Im not exactly sure what it is but it seems to be excessively rich as it struggles to stay alive.
I put new plugs in it today but they did absolutely nothing.
Could it be the AFMs?
When the car is like this, the boost gauge also "flickers" while it is in vaccum.
Any ideas?
Cheers
https://www.sau.com.au/forums/topic/25283-something-is-wrong/
Sounds like it may be a vacuum leak.
The ecu is measuring the air that comes through the AFM, but too much air gets in, so the ecu compensates by adding more fuel as it tries to maintain idle, then it over fuels, cuts the fuel - viscious cycle.
If it is vacuum, you will notice it alot more when hot than when cold too.
My guess anyways:)
have you checked all your vacuum lines?
I may have similar problems with my car.
When I stop up a hill (this occurs when driving normaly beforehand) the revs drop really low (sometimes at this point the car stalls) and then pick themselves. This loops for about 5 seconds (at a frequenct of about 1 cycle per .5sec) and then the revs stabalize.
Background:
I have a s2 R33 gtst.
I have a blitz BOV.
My AFM maxes out at less than 250rwhp on the dyno.
Sometimes when going up a hill at about 4000rpm by engine check light flashes (indicating my AFM is maxing out - its not the quick flashing that indicates pinging).
I'm running low boost (0.6bar) when this happens.
There is a Z32AFM sitting under my bed waiting to be installed to fix my AFM problems.
Anyone know what my problem is?
Mark
Well I am not sure if this is the prob, but does the pump have a non return vavle fitted? I have seen the non return valve taken off the top of 044 pumps to make them easier to connect.
I am sort of guessing :P, but when at idle the fuel pump will switch on and off as fuel pressure increases and decreases, just like when you turn the ignition on and dont start the car, the pump will prime then shut down. I am thinking that perhaps the pump is shutting down, and fuel may be returning back down the lines, which isnt a major problem until you are facing up a hill.
Have a look at boostmeisters low engine rpm stalling thread, goes into detail of wiring fuel pumps to be constantly on to avoid such dramas. Not sure if this is your prob, but may be:)
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
