The key to N/A performance is alleviating restrictions and getting things flowing optimally.
You would want to look at high flowing extractors/cat/catback exhaust and a good flowing cold air intake to get the air in and out of the engine quickly, as a minimum really to see benefit in the cams.
I would say cams are one of the last things you would throw at an N/a motor.
As N-Dawg said you should concentrate on a decent exhaust setup it'll probably cost about the same amount
Absolutely! You would probably want to look at upgrading to a larger throttle body as well.
Afterall, if you've increased the flow with exhaust and bigger cams, then increasing the size of the throttle body will allow more air into the plenum.
Remember Air + Fuel + Combustion = Power. With a turbo it's easy to force air in, but the only way you're going to get more into the N/A motor is to make every part breathe better.
well i already have a 2 1/4 straight exhaust with a high flow cat and stainless steal 4" tip. did not notice any gains. CAI is my next step thn i was thinking cams but if you are saying i should get the whole intake done first would aftermarket cams be the next ste or is there something better.
thanks
Sounds like you have a fair amount of research still to do.
2 1/2" would have been a better size to go for for the exhaust. If you're going to do cams etc.. then sorry to say but 2 1/4" is going to be restrictive as 2.75" or even 3" would make better use of the cams since you're going to be able to flow a lot more air efficiently through the exhaust system.
Generally you would want to start with an exhaust that's going to be substantial for your planned modifications, work up to extractors and high flow cat, the intake is probably the easiest part to do yourself, then later do the big things like bigger cams and cam gears, port polishing the head, and of course it reallly adds up quick if you want power out of an N/A.
I suggest a good read of the following:
How to get more power from an N/A
http://www.skylinesaustralia.com/forums/Po...sp-t194033.html
N/A power results thread
http://www.skylinesaustralia.com/forums/Na...-E-t138169.html
Also do a forum search on the N/A section for exhaust, get a good understanding of the exhaust characteristics on an N/A Skyline.
Once you have a good understanding of all that, you'll be able to put the puzzle pieces together and see how everything will work out.
After that ask questions and you'll find there's plenty of knowledgable people here that will guide you and answer your queries, but it really helps to understand the N/A Skyline first, otherwise you'll just be doing little mods here and there that may not go together as well as they could/should, and ultimately probably cost more money.
Hope that helps...
Edited by N-DAWG
dont go cams, your talkin about getting lifters, valve springs, porbably do timing belt while your there etc so u must be talkin cams with some decent lift = $$ for the amount of $ u spent buying all the gear for cams and cam gear etc you still have to install, then tune.
u could have turbocharged your n/a
Edited by Char
Yes definitely gotta factor in an ECU upgrade/piggy back on an R34, expensive exercise there. Allow $950+ Dyno Tuning (approx $400-600). I speak from experience right now as I've had a GReddy eManage fitted as part of my turbo upgrade. The R34 ECU can relearn simple things like exhaust upgrades or air filter...but throw cams into the mix and yeah tuning is going to be needed. Pretty sure you won't see the limits of the factory fuel pump and injectors though..someone confirm? btw..did you reset your ECU after the exhaust upgrade? If not, disconnect negative battery terminal, foot on the brake for 15-20 seconds, reconnect, start car, and let it relearn your driving style and adjust to the new exhaust. Don't forget to switch off the battery backup siren if you have one.
The N/A Turbo is a great cost-effective option, isn't always the cheapest option though, at least if you want to use aftermarket front/dump pipes and front mount intercoolers and high flow pod filters...and you will definitely want to upgrade that exhaust piping again to something like 3". Also speaking from experience, things easily starting costing more here and there very quickly :D
The bang per buck though on a N/A Turbo is considerably better when compared to keeping it N/A going for the big cams n all. Both options require a new ECU or Piggy Back ECU (fitting of a piggy back aint cheap, and the cost of a replacement unit like a PowerFC is expensive), and tuning which is expensive. Also note that if you have an auto box then a piggyback setup is pretty much the only way to go.
Add up the cost of the parts for the cams/cam gears and lifters etc.. compare it to buying a mix of aftermarket/factory parts for a turbo. Then work out your labour bill, yes the turbo conversion is an expensive labour exercise, but you can't tell me that doing work on the engine internals isn't! You'll probably want to change your head gasket too if you want to seek higher compression and a stronger gasket.
Can you see where things are heading cost wise?
Don't forget you'll still be using N/A model brakes which I highly recommend upgrading if you're seeking bigger power like that of a turbo, and then suspension and handling and a good set of tyres willset you back a bit too.
Since you've already done the 2 1/4" exhaust, I would either get a high flow panel filter or make a custom box and bracket in a pod filter with a cold air feed, a simple effective way to get more cooler air into the engine. Then spend money on things like suspension.
BUT before doing all that, figure out what you want to do with your car, work out your costs and options if you keep it N/A, do the same if you were to go the N/A turbo route, compare it to selling and buying the turbo car if you want a turbo, and then go from there.
All the options of getting more power out of a N/A Skyline are costly, just cause it's a Skyline doesn't mean it's going to be a powerhouse without some serious modifying.
Edited by N-DAWG
You need to be able to handle that new power gains.. performing on an ongoing basis you need to be able to control..
What point is there, to have good power, and you cant control or use it to its full capabilities?
MRXTCZ
Ok from the sounds of it you want to be happy with 15rwkw so total of 120rwkw now that you've gone 0.1 second faster how about simple suspension mods which give you 0.5 seconds by getting the power to the ground and making sure your tyres have a full contact patch to the road.... Money saved on useless mods is better saved for a conversion, for example the whiteline r33 is quicker around a track with only an exhaust and suspension mods than cars with 200+rwkw so that car is some 50rwkw down on power yet faster because of suspension
This is all very true an well.
But some people just want more poke.
I too would suggest suspension mods but if your keen for just power then;
Sort your exhaust out
Advance timing
Adjustable cam gears
piggy back/ecu
then cams
and retune
Dont even bother with new springs.
Advance timing
piggy back/ecu
then cams
and retune
do you mean advance cam timing or ignition timing
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
    • Nice, let me know how you find the 98 tune
