The key to N/A performance is alleviating restrictions and getting things flowing optimally.
You would want to look at high flowing extractors/cat/catback exhaust and a good flowing cold air intake to get the air in and out of the engine quickly, as a minimum really to see benefit in the cams.
I would say cams are one of the last things you would throw at an N/a motor.
As N-Dawg said you should concentrate on a decent exhaust setup it'll probably cost about the same amount
Absolutely! You would probably want to look at upgrading to a larger throttle body as well.
Afterall, if you've increased the flow with exhaust and bigger cams, then increasing the size of the throttle body will allow more air into the plenum.
Remember Air + Fuel + Combustion = Power. With a turbo it's easy to force air in, but the only way you're going to get more into the N/A motor is to make every part breathe better.
well i already have a 2 1/4 straight exhaust with a high flow cat and stainless steal 4" tip. did not notice any gains. CAI is my next step thn i was thinking cams but if you are saying i should get the whole intake done first would aftermarket cams be the next ste or is there something better.
thanks
Sounds like you have a fair amount of research still to do.
2 1/2" would have been a better size to go for for the exhaust. If you're going to do cams etc.. then sorry to say but 2 1/4" is going to be restrictive as 2.75" or even 3" would make better use of the cams since you're going to be able to flow a lot more air efficiently through the exhaust system.
Generally you would want to start with an exhaust that's going to be substantial for your planned modifications, work up to extractors and high flow cat, the intake is probably the easiest part to do yourself, then later do the big things like bigger cams and cam gears, port polishing the head, and of course it reallly adds up quick if you want power out of an N/A.
I suggest a good read of the following:
How to get more power from an N/A
http://www.skylinesaustralia.com/forums/Po...sp-t194033.html
N/A power results thread
http://www.skylinesaustralia.com/forums/Na...-E-t138169.html
Also do a forum search on the N/A section for exhaust, get a good understanding of the exhaust characteristics on an N/A Skyline.
Once you have a good understanding of all that, you'll be able to put the puzzle pieces together and see how everything will work out.
After that ask questions and you'll find there's plenty of knowledgable people here that will guide you and answer your queries, but it really helps to understand the N/A Skyline first, otherwise you'll just be doing little mods here and there that may not go together as well as they could/should, and ultimately probably cost more money.
Hope that helps...
Edited by N-DAWG
dont go cams, your talkin about getting lifters, valve springs, porbably do timing belt while your there etc so u must be talkin cams with some decent lift = $$ for the amount of $ u spent buying all the gear for cams and cam gear etc you still have to install, then tune.
u could have turbocharged your n/a
Edited by Char
Yes definitely gotta factor in an ECU upgrade/piggy back on an R34, expensive exercise there. Allow $950+ Dyno Tuning (approx $400-600). I speak from experience right now as I've had a GReddy eManage fitted as part of my turbo upgrade. The R34 ECU can relearn simple things like exhaust upgrades or air filter...but throw cams into the mix and yeah tuning is going to be needed. Pretty sure you won't see the limits of the factory fuel pump and injectors though..someone confirm? btw..did you reset your ECU after the exhaust upgrade? If not, disconnect negative battery terminal, foot on the brake for 15-20 seconds, reconnect, start car, and let it relearn your driving style and adjust to the new exhaust. Don't forget to switch off the battery backup siren if you have one.
The N/A Turbo is a great cost-effective option, isn't always the cheapest option though, at least if you want to use aftermarket front/dump pipes and front mount intercoolers and high flow pod filters...and you will definitely want to upgrade that exhaust piping again to something like 3". Also speaking from experience, things easily starting costing more here and there very quickly :D
The bang per buck though on a N/A Turbo is considerably better when compared to keeping it N/A going for the big cams n all. Both options require a new ECU or Piggy Back ECU (fitting of a piggy back aint cheap, and the cost of a replacement unit like a PowerFC is expensive), and tuning which is expensive. Also note that if you have an auto box then a piggyback setup is pretty much the only way to go.
Add up the cost of the parts for the cams/cam gears and lifters etc.. compare it to buying a mix of aftermarket/factory parts for a turbo. Then work out your labour bill, yes the turbo conversion is an expensive labour exercise, but you can't tell me that doing work on the engine internals isn't! You'll probably want to change your head gasket too if you want to seek higher compression and a stronger gasket.
Can you see where things are heading cost wise?
Don't forget you'll still be using N/A model brakes which I highly recommend upgrading if you're seeking bigger power like that of a turbo, and then suspension and handling and a good set of tyres willset you back a bit too.
Since you've already done the 2 1/4" exhaust, I would either get a high flow panel filter or make a custom box and bracket in a pod filter with a cold air feed, a simple effective way to get more cooler air into the engine. Then spend money on things like suspension.
BUT before doing all that, figure out what you want to do with your car, work out your costs and options if you keep it N/A, do the same if you were to go the N/A turbo route, compare it to selling and buying the turbo car if you want a turbo, and then go from there.
All the options of getting more power out of a N/A Skyline are costly, just cause it's a Skyline doesn't mean it's going to be a powerhouse without some serious modifying.
Edited by N-DAWG
You need to be able to handle that new power gains.. performing on an ongoing basis you need to be able to control..
What point is there, to have good power, and you cant control or use it to its full capabilities?
MRXTCZ
Ok from the sounds of it you want to be happy with 15rwkw so total of 120rwkw now that you've gone 0.1 second faster how about simple suspension mods which give you 0.5 seconds by getting the power to the ground and making sure your tyres have a full contact patch to the road.... Money saved on useless mods is better saved for a conversion, for example the whiteline r33 is quicker around a track with only an exhaust and suspension mods than cars with 200+rwkw so that car is some 50rwkw down on power yet faster because of suspension
This is all very true an well.
But some people just want more poke.
I too would suggest suspension mods but if your keen for just power then;
Sort your exhaust out
Advance timing
Adjustable cam gears
piggy back/ecu
then cams
and retune
Dont even bother with new springs.
Advance timing
piggy back/ecu
then cams
and retune
do you mean advance cam timing or ignition timing
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
